查看: 318|回复: 0
EL和SL系列演示板
  • 签到天数: 11 天
    发表于 2012-8-22 09:58:16 | 显示全部楼层 |阅读模式
    DEMO9S08EL32是飞思卡尔的9S08EL和9S08SL系列微控制器的演示板。Application development is quick and easy with the integrated USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. Two, 40 pin connectors provide access to all I/O signals on the target MCU.
    Features
    • MC9S08EL32, 28 TSSOP
    • Integrated P&E USB-BDM
    • BDM_PORT header for BDM cable support (not installed)
    • LIN PHY with 2, 4-pos Molex connectors
    • MCU_PORT socket headers for access to MCU I/O signals
    • On-board +5V regulator
    • Optional Power from USB-BDM or MCU_PORT connector
    • Power Input Selection Jumpers
    • 3 Push Switches; 2 User, 1 Reset
    • 7 LED Indicators; 2 User, VDD, USB Power, USB Power Out
    • 5K ohm POTs with LP Filter
    • Light Sensor with LP Filter and Op Amp
    下载连接:
    EL和SL系列演示板用户指南
    GMT+8, 2024-11-27 04:18 , Processed in 0.108860 second(s), 15 queries , MemCache On.
