查看: 315|回复: 0
S08EL/SL演示板
  • 签到天数: 11 天
    发表于 2012-8-22 09:50:31 | 显示全部楼层 |阅读模式
    DEMO9S08EL32是飞思卡尔9S08EL和9S08SL系列微控制器的演示板。
    Application development is quick and easy with the integrated USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. Two, 40 pin connectors provide access to all I/O signals on the target MCU.
    特性:
    • MC9S08EL32, 28 TSSOP
      • 32K Bytes Flash
      • 1K Bytes RAM
      • 512K Bytes EEPROM
      • Internal Oscillator
    • Integrated P&E USB-BDM
    • BDM_PORT header for BDM cable support (not installed)
    • LIN PHY with 2, 4-pos Molex connectors
    • MCU_PORT socket headers for access to MCU I/O signals
    • On-board +5V regulator
    • Optional Power from USB-BDM or MCU_PORT connector
    • Power Input Selection Jumpers
      • Power input from USB-BDM
      • Power input from on-board regulator
      • Power input from Connector J1
      • Optional Power output through Connector J1
    • User Components Provided
      • 3 Push Switches; 2 User, 1 Reset
      • 7 LED Indicators; 2 User, VDD, USB Power, USB Power Out
      • 5K ohm POTs with LP Filter
      • Light Sensor with LP Filter and Op Amp
    • Jumpers
      • PWR_SEL
      • VX_EN
      • USER_EN
      • COM_SEL
    • Connectors
      • 40-pin MCU I/O Connector
      • 2.0mm Barrel Connector
      • BDM_PORT (not installed)
      • USB Connector
      • DB9 Connector
    下载连接:
    S08EL/SL演示板用户指南
    GMT+8, 2024-11-27 04:34 , Processed in 0.106104 second(s), 15 queries , MemCache On.
