TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
DEMO9S08SH8/SG8是飞思卡尔MC9S08SH和MC9S08SG微控制器的演示板。
Application development is quick and easy with the integrated USB-BDM, sample software tool, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. Two, 40-pin connectors provide access to all I/O signal on the target MCU.
特性:
- S08SH8, 20PDIP
- 8K Bytes Flash
- 512 Bytes RAM
- Internal Oscillator
- Integrated P&E USB-BDM
- BDM_PORT header for BDM cable support (not installed)
- MCU_PORT socket header for access to MCU IO signals
- On-board +5V regulator
- Optional power from USB-BDM or MCU_PORT connector
- User Components Provided
- 3 Push Switches; 2 User, 1 Reset
- 7 LED Indicators; 2 User, VDD, USB Power, USB Power Out
- 5K ohm POTs w /LP Filter
- Light Sensor w/ LP Filter and Op Amp
- Connectors
- 40-pin MCU I/O Connector
- 2.0mm Barrel Connector
- BDM_PORT (not installed)
- USB Connector
- DB9 Connector
下载连接:
MC9S08SG8/4演示板用户指南 |
