查看: 334|回复: 0
MC9S08SG32演示板
  • 签到天数: 11 天
    发表于 2012-8-21 16:49:44 | 显示全部楼层 |阅读模式
    DEMO9S08SH32/SG32是MC9S08SH和MC9S08SG微控制器的演示板。
    Application development is quick and easy with the integrated USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. Two, 40-pin connectors provide access to all IO signals on the target MCU.
    特性:
    • MC9S08SH32/SG32, 28 TSSOP
      • 32K Bytes Flash
      • 1K Bytes RAM
      • 512K Bytes EEPROM
      • Internal Oscillator
    • Integrated P&E USB-BDM
    • BDM_PORT header for BDM cable support (not installed)
    • LIN PHY w/ 2, 4-pos Molex connectors
    • MCU_PORT socket headers for access to
    • MCU IO signals
    • On-board +5V regulator
    • Optional Power from USB-BDM or MCU_PORT connector
    • Power Input Selection Jumpers
      • Power input from USB-BDM
      • Power input from on-board regulator
      • Power input from Connector J1
      • Optional Power output through Connector J1
    • User Components Provided
      • 3 Push Switches; 2 User, 1 Reset
      • 7 LED Indicators; 2 User, VDD, USB Power, USB Power Out
      • 5K ohm POTs w /LP Filter
      • Light Sensor w/ LP Filter and Op Amp
    • Connectors
      • 40-pin MCU I/O Connector
      • 2.0mm Barrel Connector
      • BDM_PORT (not installed)
      • USB Connector
      • DB9 Connector
    下载连接:
    MC9S08SG32演示板用户指南
    GMT+8, 2024-11-27 04:35 , Processed in 0.114924 second(s), 15 queries , MemCache On.
