查看: 308|回复: 0
MCF51MM 医疗开发模块
发表于 2012-8-21 16:50:08 | 显示全部楼层 |阅读模式
TWR-MCF51MM模块是一个MCF51MM256 Flexis ColdFire 32位MCU开发板。It is designed to aid in the evaluation and prototyping of medical applications and includes an electrocardiograph sensor (MED-EKG) as part of the evaluation system.The TWR-MCF51MM operates as a standalone debug tool and can also be combined and used as part of the modular Tower System development platform.
Features
  • Integrated open-source BDM debugging tool
  • Small form factor
  • Supports external communications interfaces
  • Includes power regulation circuitry with standardized bus
  • Two 80-pin connectors on the outside to support debugging or expansion to LCD module
  • RS232, RS485, CAN , USB
  • Open connector for MED-EKG development board
  • Low power
  • The TWR-MCF51MM board contains a Flexis MCF51MM256, an Energy-Efficient Product Solution by Freescale
Kit Contains
  • Part Number TWR-MCF51MM contains:
    • TWR-MCF51MM board with a MCF51MM256 32-bit MCU
    • DVD with lab tutorials, software, training and collateral
    • Quick Start Guide document
  • Part Number TWR-MCF51MM-KIT also contains:
    • TWR-SER - Tower System Serial Module
    • TWR-ELEV - Tower System Elevator Modules
    • MED-EKG - Electrocardiograph development kit for Tower System
    • Necessary cables
下载连接:
TWR-MCF51MM 用户手册
MCF51MMQSG/ TWR-MCF51MM 快速参考手册
GMT+8, 2024-11-27 04:34 , Processed in 0.124688 second(s), 15 queries , MemCache On.
