查看: 385|回复: 0
S08D系列演示板
  • 签到天数: 11 天
    发表于 2012-8-21 16:22:51 | 显示全部楼层 |阅读模式
    DEMO9S08DZ60演示板是针对MC9S08DZ60微控制器设计的。Application development is quick and easy with the integrated USB-BDM, sample software tools, and examples. An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. Two, 40-pin connectors provide access to all IO signals on the target MCU.DEMO9S08DZ60 Features
    • MC9S08DZ60, 64 LQFP
    • 32K Bytes Flash
    • 4K Bytes RAM
    • 2K Bytes EEPROM
    • Timing Sources
    • 4 MHz XTAL
    • OSC socket
    • BNC connector
    • Integrated P&E USB-BDM
    • BDM_PORT header for BDM cable support (not installed)
    • LIN PHY w/ 2, 4-pos Molex connectors
    • HS-CAN PHY w/ 3-pos pin header connector
    • LP Filters on ADC inputs
    • 2 ea., MCU_PORT socket headers for access to MCU IO signals
    • On-board +5V regulator
    • Optional Power from USB-BDM or MCU_PORT connector
    • Power Input Selection Jumpers
    • Power input from USB-BDM
    • Power input from on-board regulator
    • Power input from Connector J1
    • Optional Power output through Connector J1
    • User Components Provided
    • 3 Push Switches; 2 User, 1 Reset
    • 1 4-pos DIP Switch 7 LED Indicators; 4 User, VDD, USB Power, USB Power Out
    • 2ea. 5K ohm POTs w /LP Filter
    • Jumpers
    • Connectors
      • 2 40-pin MCU I/O Connector
      • 2.0mm Barrel Connector BDM_PORT
      • USB Connectors
      • DB9 Connector
    下载连接:
    S08D系列演示板用户指南
    GMT+8, 2024-11-27 04:37 , Processed in 0.110555 second(s), 15 queries , MemCache On.
