查看: 290|回复: 0
MC908JL16 演示板
  • 签到天数: 11 天
    发表于 2012-8-21 14:46:46 | 显示全部楼层 |阅读模式
    DEMO908JL16演示板是针对MC908JL16微控制器的评估演示板。Development of application code is quick and easy with the integrated USB-to-MON08 interface, CodeWarrior Development Studio, and software examples. A I/O connector allows connecting the DEMO908JL16 board to an expanded evaluation environment.Features
    • An MCU section containing
      • An MC68HC908JL16 microcontroller (in 32–pin SDIP package, already programmed with a demo application–in addition, you can also use any other pinto–pin–compatible device)
      • One clock sources: a 9.8304 MHz crystal, selectable via the "OSC ENA" jumper.
    • A power supply section containing
      • A 12 V DC Power Supply Input Connector
      • Power input selection jumpers for selecting the input voltage input source
        • 12 V DC input connector
        • USB connector
        • I/O header connector
    • A built–in "USB TO MON08" section which allows the host PC to communicate with the microcontroller through a standard USB interface. USB 2.0 is fully supported. When using an external in-circuit debugger (via the "MON08" connector), the "USB TO MON08" circuitry must be bypassed by removing all of the J402 jumper
    • A Reset section containing a Reset push-button connected to the MCU Reset pin
    • An input section containing
      • Two push–buttons together with jumpers to connect/disconnect them to/from the PTA0 and PTA1 pins of the microcontroller
      • A potentiometer, together with a jumper to connect/disconnect it to/from the PTD3/ADC8 pin of the microcontroller
    • An output section containing two high–efficiency (low–current) LEDs together with two jumpers to connect/disconnect them to/from the PTD4 and PTD5 pins of the microcontroller.
    • An RS–232 section providing one RS–232 channel connected to the microcontroller’s SCI serial communication interface. The microcontroller’s PTD6/TxD and PTD7/RxD lines are used by the RS–232 channel.
    • An accelerometer section featuring a Freescale MMA7260Q sensor. All of the sensor’s input/output lines are connected to the microcontroller via jumpers.
    下载连接:
    MC908JL16 演示板用户指南
    GMT+8, 2024-11-27 06:24 , Processed in 0.110837 second(s), 15 queries , MemCache On.
