TWR-WIFI-RS2101 外设模块让易于使用的 802.11n Wi-Fi 连通性成为可行,可用于塔式系统的应用开发。This FCC-certified module comes with complimentary MQX™ software and enables you to quickly go from the lab to production with the same Wi-Fi hardware.The on-board RS9110-N-11-21 Connect-io-n™ Wi-Fi module from Redpine Signals features embedded firmware to provide a self-contained 802.11n WLAN solution for a variety of applications. This peripheral module is designed to be combined and used with other MCU and peripheral modules in the Tower System.
Features
RS9110-N-11-21 Wi-Fi module from Redpine Signals
Compliant to 802.11b/g and single stream 802.11n
Supports all Wi-Fi client security protocols (WEP, WPA and WPA2)
Reference design certified for FCC/IC/CE
RoHS compliant
Does not require any WLAN driver on the host processor
Interfaces to MCU via SPI, UART
Terminates SLIP connections and offers transparent serialmodem functionality
Integrated antenna, frequency reference and low-frequency clock
Ultra-low-power operation with power save modes
Ad-hoc and infrastructure modes for maximum deployment flexibility
Single supply 3.1 to 3.6V operation
Kit Contains
TWR-WIFI-RS2101 board with Redpine Signals’ RS9110–N–11–21 Wi–Fi module
