查看: 401|回复: 0
MCF5272 评估板
发表于 2012-8-21 13:44:24 | 显示全部楼层 |阅读模式
 M5272C3 评估板为着手高性能嵌入式设计提供了很好的工具。
With 4 MBytes of SDRAM, 2 MByte of Flash, 10/100 BaseT ethernet connectivity, two serial ports, available expansion of 512 KByte SRAM for high-speed critical code or benchmarking, USB device port and access to the best-in-class ColdFire debug module. This complete package includes all the components for realizing an MCF5272 design quickly and easily.
Features
  • MCF5272 processor running at 66 MHz internal
  • Monitor/Debugger programmed on 2 MByte of FLASH with 1.7 MBytes of FLASH available for customer use
  • 4 MBytes of SDRAM
  • Integrated 10/100 BaseT ethernet connectivity via RJ-45 connector
  • 1 channel DMA
  • USB device mode support
  • Dual programmable UARTs (universal asynchronous/synchonic receiver/transmitter) - 1 available for customer use
  • Debug module interface connector (used with source level debuggers running on PC's)
  • Serial cable (gives access to ROM monitor which includes in-line assembler)
  • All CPU signals available via two 120-pin expansion connectors
  • Small form factor
  • Power Requirements are +5 to +14 Volts DC regulated or unregulated (on board regulation to +3.3 V DC)
Kit Contains
  • Printed Wiring Board Assembly, M5272C3 RE10795B Rev. 2.2
  • Cable: DB9 M/F Serial Data Cable
  • Cable: DB25 M/F Parallel Port Interface Extension Cable
  • Cable: ColdFire BDM (wiggler) cable
  • Book: M5272C3 User's Manual Rev 1.4
  • Document: M5272C3 Product Deviation / Errata
  • Book: MCF5272 ColdFire Integrated Microprocessor User's Manual & Errata*
  • Book: ColdFire Family Programmers Reference Manual Rev. 2*
  • Document: Technical Support contact info. for Freescale Semiconductor Products
  • Tools: Metrowerks CodeWarrior evaluation CD, datasheet and quick start guide
  • Tools: Various development tool vendor contacts, evaluations and/or datasheets*
*May be substituted with procurement and/or contact information if not available at kit assembly time.
下载连接:
M5272C3 评估板手册
USB Host Driver v03
GMT+8, 2024-11-27 06:10 , Processed in 0.111434 second(s), 15 queries , MemCache On.
