TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
KIT33810EKEVME评估套件突出了MC33810 汽车发动机控制 IC,这是 8 个通道输出 供汽车发动机控制应用功能的驱动 IC。 The IC consists of four integrated low side drivers and four low side gate pre-drivers. The low side drivers are suitable for driving fuel injectors, solenoids, lamps, and relays. The four gate pre-drivers can function either as ignition IGBT gate pre-drivers or as general purpose MOSFET gate pre-drivers.The PCB contains an MC68HC908JW32 MCU, which provides a USB to SPI interface communication translation, to allow interface to the evaluation board from a PC.
特性:
- Designed to Operate over the range of 4.5 V ≤ VPWR ≤ 36 V
- Quad Ignition IGBT or MOSFET gate pre-driver with Parallel/SPI and/or PWM Control
- Quad Injector Driver with Parallel/SPI Control
- Interfaces Directly to MCU Using 3.3 V / 5.0 V SPI Protocol
- Injector Driver Current Limit - 4.5A Typical
- Independent Fault Protection and Diagnostics
- VPWR Standby Current 10 µA Typical
下载连接:
KIT33810EKEVME评估套件用户指南 |
