M5485EVB 开发系统为MCF548x 处理器嵌入式设计提供了所需的所有工具。The kit contains a system-on-module, called a Fire Engine, containing 64 MBytes of DDR-SDRAM, 16 MB of Flash, and a graphics contoller. The Fire Engine module, along with the included ethernet ports, PCI slots, CAN interfaces, serial interfaces, and the best-in-class ColdFire debug module generates a complete package to enable quick design support for the MCF5485, MCF5484, MCF5483, MCF5482, MCF5481, or MCF5480 processors.
Features
- ColdM5485CFE Fire Engine Module (SOM-ETX), including:
- MCF5485CZP200 Processor
- 64MB DDR-SDRAM
- 16MB Flash
- Graphics Controller
- USB Host Controller
- LCD Display Connector - includes integrated LCD, touch, and backlight connector for Display Kits
- DVI Connector
- Two 10/100 RJ45 Ethernet connectors
- Two PCI slots (32 bit, 33 or 66MHz, 3.3V)
- Serial Ports
- Two RS-232 Serial Ports
- Two TTL Serial Ports
- Two CAN 2.0B Interfaces
- USB 2.0
- One High Speed Device (on Fire Engine)
- Four High Speed Host ports
- SPI
- RTC
MCF5485 Fire Engine Configurations
The M5485EVB development kit contains a module, called a Fire Engine, which can be purchased from Freescale in production volumes. The MCF5485 Fire Engine is a complete system on module (in SOM-ETX format) offering essential features for industrial and embedded networking applications. The use of the Mini-ITX baseboard included in the M5485EVB, or a custom peripheral board generated by the customer makes the Fire Engine the ideal foundation for developing embedded computing products. The Fire Engine provides a common reference pin-out on its expansion connectors, which enables customers to easily scale to next generation microprocessor Fire Engines when new functionality or performance is required.The table below shows all MCF5485 Fire Engine Module configurations that are available from Freescale, manufactured by LogicPD.Part Number | DDR Memory (MB)
| NOR Flash (MB)
| Boot Flash (MB)
| Graphics Ctrl
| Audio
| USB Host
| M5485AFE | 64
| 0
| 2
| No
| Yes
| No
| M5485BFE | 64
| 16
| 2
| No
| Yes
| No
| M5484GFEE* | 64
| 0
| 4
| No
| Yes
| Yes
| M5484GFEE* | 64
| 0
| 4
| No
| Yes
| Yes
| M5485HFEE** | 64
| 16
| 2
| Yes
| Yes
| Yes
| * The M5484GFEE Fire Engine Module is included in the M5484LITEKIT.** The M5485HFEE Fire Engine Module is included in the M5485EVBE.M5485EVB Display Kit Options
LCD Display Kits from LogicPD for the M5485EVB are available which include bezel, inverter, touch panel, and cables.These optional LCD Display kits are designed to work directly with M5485EVB and will be available through Digi-Key.Part Number | Display Type
| MQVGADK | QVGA - 240x320 - 3.5"
| MVGADK | VGA - 640x480 - 6.4"
| MSVGADK | SVGA - 800x600 - 12.1"
下载连接:
MCF548x 参考手册
入门飞思卡尔开发工具手册 |
