TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
ZK-HC08EY-A入门工具包是飞思卡尔 MC68HC908EY 微控制器的全功能和入门使用的评估板。A 32-pin Yamaichi QFP ZIF (Zero Insertion Force) socket is provided which allows easy microcontroller insertion/extraction--the Starter Kit can be used as a single programmer. The Starter Kit takes advantage of the CodeWarrior Development Studio Special Edition (which groups an Editor, Assembler, C Compiler and Debugger) and the Freescale MON08 interface, which allows the download and debug of the user application into the microcontroller's FLASH memory. Together with CodeWarrior, the Starter Kit provides you with everything you need to write, compile, download, in-circuit emulate and debug user code. Full-speed program execution allows you to perform hardware and software testing in real time. The Starter Kit is connected to the host PC through a USB port. A prototyping area allows you to wire your own small application.
Features
- Full-Featured Evaluation Board with LIN, RS-232, LEDs, Push-Buttons, DIP-Switches, Potentiometer
- ZIF Socket for Experimenting with Different Microcontrollers
- True, Built-In MON08 Debugging through USB Interface
- CodeWarrior Development Studio Special Edition Included, with Editor, Assembler, C Compiler and Debugger
下载连接:
MC68HC908EY 入门工具包用户指南
MC68HC908EY 入门工具电路图 |
