查看: 351|回复: 0
MC68HC908QY4入门工具包
  • 签到天数: 11 天
    发表于 2012-8-20 14:05:07 | 显示全部楼层 |阅读模式
    PK-HC08QY4入门工具包目的是评估MC68HC908QY4微控制器和调试其小型设计。The PK-HC08QY4 Starter Kit takes advantage of the CodeWarrior Integrated Development Environment (which groups an Editor, Assembler, C Compiler and Debugger) and the Freescale's MON08 interface, which allows the download of the user application into the microcontroller FLASH memory. Together with CodeWarrior, PK-HC08QY4 provides you with everything you need to write, compile, download, in-circuit emulate and debug user code. Full-speed program execution allows you to perform hardware and software testing in real time. PK-HC08QY4 is connected to the host PC through a USB port. A prototyping area allows you to wire your own small application.
    Features
    • True MON08 Debugging through USB Interface
    • CodeWarrior (Special Edition) Included, with Editor, Assembler, C Compiler and Debugger
    • Working Experiments in Minutes
    下载连接:
    MC68HC908QY4入门工具包用户指南
    MC68HC908QY4入门工具电路图
    GMT+8, 2024-11-27 06:37 , Processed in 0.109093 second(s), 15 queries , MemCache On.
