查看: 401|回复: 0
混合信号PICtail演示板
  • 签到天数: 11 天
    发表于 2012-8-17 11:32:32 | 显示全部楼层 |阅读模式
    混合信号PICtail™ 演示板 将快速精确地评估微芯多种数模转换器、模数转换器、低压差线性稳压器和运算放大器的性能。The board interfaces to the PICkit™ 1 Flash Starter Kit or can utilize the on-board PIC16F767 for “stand-alone” operation. The user can take advantage of the existing PIC® microcontroller library of software routines or develop their own routines. The PIC® microcontroller can select which DAC to configure, which ADC channel to read, and utilize a dual op-amp for various buffer implementations.Features:
    • 4 layer board for low noise evaluation
    • Supports the following Microchip Mixed Signal devices (surface mount footprint):• MCP492X SPI DACs• TC132X I2C DACs• MCP330X and MCP320X SPI SAR ADCs• MCP3221 and MCP3021 I2C SAR ADCs• MCP1525 and MCP1541 Voltage References• MCP170X LDOs
    • PIC16F767-I/SS footprint with ICSP™ (In-Circuit Serial Programming™) interface
    • Sample kit contains a number of applicable Microchip DACs, ADCs, LDOs and Vrefs
    下载连接:
    ADSP-BF548 EZ-KIT Lite 评估系统手册
    GMT+8, 2024-11-27 06:15 , Processed in 0.114610 second(s), 15 queries , MemCache On.
