MCP3551 Delta-Sigma ADC演示板目的是在PC机上利用DataView™软件演示微芯技术的MCP3551 22位 Delta-Sigmas模数转换器的性能。The demo board can be used with MPLAB® ICD2, PICkit™ 1 Flash Starter Kit, or PICkit™ 2 for developing demonstration/evaluation firmware. Optionally, a second installed MCP3551 can be used with and optional stimulus board (sold separately).The board is designed to evaluate the MCP3551 with minimum Printed Circuit Board (PCB) noise. The PCB layout practices low-noise design to reduce the signal noise as much as possible in order to demonstrate the 22-Bit performance of the MCP3551.Features:
Three precision potentiometers for demonstrating the capabilities of the MCP3551
On-board PIC18F4550 with USB for DataView communication
USB interface for connecting to a PC
Dataview™ software with easy-to-read format and data logging
Three headers/connectors for programming the PICmicro® using any of the following:• PICkit™1 Flash Starter Kit• PICkit™2• MPLAB® ICD2 (debugger and programmer)
