查看: 396|回复: 0
ADSP-BF518F EZ-BOARD 评估板
发表于 2012-8-17 09:47:41 | 显示全部楼层 |阅读模式
Blackfin BF518F EZ-Board 评估板为开发者提供了通过外部JTAG仿真器或独立调试板的ADSP-BF512/F, BF514/F, BF516/F, BF518/F Blackfin处理器初步廉价开发平台。The EZ-Board also supports uClinux®. Note: To debug you must have a Debug Agent Board or Emulator. The EZ-Board has an expansion interface that allows for modularity with different EZ-Extender boards.FEATURES
  • ADSP-BF518F: 400 MhZ, 176 Lead LQFP
  • SDRAM: 64 MB, 32M x 16, Micron MT48LC32M16A2TG ,3.3V
  • FLASH: 4 MB (2M x 16 ), Numonyx M29W320DB 3.3V, FBGA48
  • SPI FLASH: 4 Mb on-chip SPI 1.8V
  • Audio CODEC: ADI SSM2602 CODEC 3.3 Volts, 12MHz input
  • A/D Converter: AD7266, Differential/Single-Ended Input, Dual 2 MSPS, 12 bit 3 Channel
  • Power Analysis Interface: Precision resistors to measure VDDINT, VDDEXT, VDDMEM, VDDFLASH
  • Ethernet PHY: National Semiconductor 10/100 Single Port PHY
  • LEDs: 13 LEDs: 1 power (green), 1 board reset (red), 3 general purpose (amber), 8 Ethernet (amber)
  • RTC Battery: 3.0 Volt Li-ION, CR2430 (270mAh)
  • Connectors: Ethernet, SD, EBIU Expansion, Group 1A and 1B Expansion, Group 2A Expansion
System Requirements
  • Windows® 2000 SP4, Windows XP SP2, Windows Vista™ or (from update 7) Windows 7 Business/ Enterprise/ Ultimate editions
  • Intel Pentium® processor (x86 compatible), 1 GHz or faster
  • 512 MB RAM and 2 GB available hard disk space
  • VisualDSP++ 5.0 Update 5
下载连接:
HPUSB, USB, HPPCI Emulators 用户指南
ADSP-BF518F EZ-Board评估系统手册
Blackfin EZ-Extender手册
GMT+8, 2024-11-27 06:16 , Processed in 0.101499 second(s), 15 queries , MemCache On.
