查看: 366|回复: 0
MCP6SX2 PGA光电二极管 PICtail演示板
  • 签到天数: 11 天
    发表于 2012-8-16 17:05:07 | 显示全部楼层 |阅读模式
    MCP6SX2 PGA光电二极管 PICtail演示板突出了PNZ334 光电二极管、 MCP6001U 运算放大器、 MCP6S22 和 MCP6S92 可编程增益放大器(PGA)的功能 。The op amp converts the photodiode’s output current to voltage (transimpedance amplifier). Its output goes to one of the PGA’s inputs. The other PGA input is available for any other desired source. This opens the possibilities of processing other sensor signals, and of increasing the number of PIC® microcontroller I/O pin available for other purposes.This board works with the PICkit™ 1 Flash Starter Kit (see DS40051) and the Signal Analysis PICtail™ Daughter Board (see DS51476). With these additional tools, a complete solution is achieved: PC software interface, PICmicro® microcontroller, firmware programmability, 10-bit ADC (on the microcontroller), and firmware (with re-locatable assembler code) for the microcontroller.Features:
    • On-Board photodiode
    PGA
    • Buffers the transimpedance amplifier’s output
    • Provides multiple gains
    • Provides an additional input
    • On-board transimpedance amplifier
    下载连接:
    MCP6SX2 PGA光电二极管 PICtail演示板用户指南
    GMT+8, 2024-11-27 06:20 , Processed in 0.111824 second(s), 15 queries , MemCache On.
