MCP6S22 PGA PICtail™演示板目的是评估和演示微芯技术的MCP6S21/2/6/8可编程和MCP6S91/2/3 增益放大器 (PGA)系列。Interface this board with Microchip’s PICkit™ 1 Flash Starter Kit to demonstrate firmware integration between the PIC MCU and PGA devices, while allowing you to modify and develop firmware for your specific requirementsThe MCP6S22 PGA PICtail™ Demo Board can also be used in stand-alone mode, wherein the board uses a:
USB interface to communicate directly to a Personal Computer (PC)
Graphical User Interface (GUI) to display the PGA output voltage
特性:
Demonstrates MCP6S22/92 PGA functionality
Interfaces to the PICKit™ 1 Flash Starter kit
Interfaces directly to a PC via the USB port for stand-alone mode of operation
13-Bit Analog-to-Digital Converter (ADC) with SPI interface
An optical sensor circuit connects to the PGA
An adjustable voltage source connects to the PGA
Four-layer PCB with separate ground and power supply planes provide noise immunity
