查看: 339|回复: 0
USB PICtail Plus子板
  • 签到天数: 11 天
    发表于 2012-8-16 16:15:14 | 显示全部楼层 |阅读模式
    简介USB PICtail. Plus子板是配合Explorer 16开发板评估微芯技术的16位和32位USB产品的USB演示板。特性. Example circuits for USB device, embedded host and On-The-Go (OTG). Both horizontal and vertical PICtail Plus Daughter Board connection interfaces入门指南The USB PICtail Plus Daughter Board is attached to the Explorer 16 Development Board, either through the J5 connector, or by attaching to the edge of the Explorer 16 via the horizontal PICtail Plus Daughter Board connection interface. The USB PICtail Plus Daughter Board is capable of sourcing 100 mA to VBUS when operating as an embedded host or in OTG mode. If the desired application requires more than100 mA for an embedded host application, then a +5V power supply must be attached to the +5V rail of the Explorer 16. OTG applications are limited to sourcing 100 mA on VBUS.开发板配置There are four jumpers on the board to select the operational mode and optional features.
    GMT+8, 2024-11-27 06:16 , Processed in 0.106578 second(s), 15 queries , MemCache On.
