查看: 249|回复: 0
PICtail Plus 电机控制子卡
  • 签到天数: 11 天
    发表于 2012-8-16 15:09:26 | 显示全部楼层 |阅读模式
    PICtail Plus电机控制子板与Explorer 16开发和高压/低压电源模块接口。此开发板的多个测试点将让您的应用调试程序更简单。It also has hardware support for sensor and sensor-less applications such as Hall sensors, optical encoder, back EMF and current sensing. This uses dsPIC33F device family for the MC development as opposed to the DM300020 that targets dsPIC30F for the MC application development. This board comes with a Motor Control 100-pin Plug In Module to be used on the Explorer 16 board.Features:
    • Connector to Explorer 16
    • Connector to HV/LV Power Module
    • Motion sensor inputs: Hall Sensors or Optical Encoder
    • Test points for motor currents, PWM and voltages
    下载连接:
    PICtail Plus 电机控制子卡用户指南
    GMT+8, 2024-11-27 06:41 , Processed in 0.109666 second(s), 15 queries , MemCache On.
