查看: 318|回复: 0
MCP42XX PICtail Plus子板
  • 签到天数: 11 天
    发表于 2012-8-16 13:15:39 | 显示全部楼层 |阅读模式
    MCP42XX PICtail Plus子板目的是演示MCP42XX 数字电位器的如何操作。MCP41XX的操作与MCP42XX相类似,因此,此演示板可用于MCP42XX和MCP41XX的开发平台。This board is designed to be used in conjunction with either the PIC24 Explorer 16 Demo Board or the PICkit™ Serial Analyzer.Each digital potentiometers Terminal A pin can be individually connected to either AVDD or the corresponding VAx padFeatures:
    • Each digital potentiometers Terminal B pin can be individually connected to either AVSS or the corresponding VBx pad
    • Can control the voltage on the MCP4261’s CS pin to either VSS, 3.3V, 5.0V, or 9.0V via control signals from the PICtail Plus interface (J3)
    • Can Control the MCP4261 via the PICkit™ Serial Analyzer interface (J1)
    • PIC24 can monitor the voltage levels of the MCP4261’s W0 and W1 pins
    • Supplied with a “C” program that demonstrates normal and high voltage commands
    • Demonstrates a split rail application, with digital logic at 3.3V and analog operation at 5.0V
    Other Requirements:
    • Requires either PICkit Serial Analyzer or Explorer 16 Demo Board
    下载连接:
    MCP2515 PICtail Plus子板用户指南
    GMT+8, 2024-11-27 06:20 , Processed in 0.131426 second(s), 18 queries , MemCache On.
