查看: 439|回复: 0
SHARC Audio EZ-Extender 扩展板
发表于 2012-8-16 11:00:56 | 显示全部楼层 |阅读模式
SHARC Audio EZ-Extender给用户提供了在ADSP-214xx EZ-Board/ EZ-KIT Lite上评估音频应用的能力。在最新更新的VisualDSP + +中提供了软件例子。The EZ-Extender consists of three Analog Devices AD1939 audio codecs and provides 24 channels of analog audio out, 12 channels of analog audio in. The primary codec operates in both in I2S and TDM mode and can run at sample rates of 48, 96, or 192 KHz. The other two codec are configured to operate in Dual Line TDM mode. The three codecs together can operate in dual line TDM mode for 24 analog channels out and 12 analog channels in at a sample rate of 192KHz.The audio input and output is available via multiple RCA connectors. A group of switches are available if a user should decide to evaluate the audio codec inputs and outputs in a differential mode. (NOTE: DB25 to XLR cables are not supplied with the EZ-Extender).
下载连接:
HPUSB, USB, HPPCI Emulators 用户指南
SHARC处理器编程参考
SHARC Audio EZ-Extender 手册
ADSP-21469 EZ-Board 评估系统手册
Blackfin/SHARC EZ-Extender系统手册
GMT+8, 2024-11-27 06:40 , Processed in 0.112541 second(s), 15 queries , MemCache On.
