TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
简介IrDA PICtail ™ Plus 子板是设计与微芯的Explorer 16或其他带PICtail Plus 连接器和AN1071 IrDA Standard Stack的开发板一起使用,用于创建 IrDA 启用的开发和评估平台。The IrDA Stack is written to operate with the IrDA-enabled UARTs on the 16-bit PIC24 MCUs, PIC32 MCUs and dsPIC33 DSCs.特性
- Infrared optical sensor.
- PICtail™ Plus Daughter Board connection interface
入门指导To get started, an Explorer 16 development board is required. All Explorer 16 development boards are shipped with connector J5 installed. The IrDA® Standard PICtail Plus Daughter Board should be inserted into one of the top two sockets of J5. The orientation of the IrDA Standard PICtail Plus Daughter Board should be such that the optical sensors points toward the prototyping area on the Explorer 16 development board. If the board is inserted into the top most socket, UART1 must be utilized for infrared communication. If the board is inserted into the second top most sockets, UART2 must be utilized for infrared communication.The IrDA™ Standard PICtail Plus Daughter Board can be used in conjunction with the IrDA Standard Stacks for Microchip 16-bit and PIC32 microcontrollers (see application note AN1071). The demonstration projects provided with the stack can be programmed into an Explorer 16 demonstration board and interact with either Explorer 16 demonstration board, or another device that also supports the pertinent IrDA® Standard protocol.IrDA Stack and FirmwareThe Microchip IrDA Standard stack is available for free download with AN1071 at this link.信号接口Functions | I/O | Pin | Description | RX | I | U1RX/U2RX | UART Receive | TX | O | U1TX/U2TX | UART Transmit |
下载连接:
IrDA PICtail Plus子卡简介 |
