查看: 459|回复: 0
Arduino Proto扩展板
  • 签到天数: 11 天
    发表于 2012-8-14 17:10:21 | 显示全部楼层 |阅读模式
    Overview
    Arduino 原型扩展板让您的设计更加的简单,您可以焊接您需要的在原型区域来开发新的产品,或者将它和一个小型的面包板一起使用来快速测试电路参数。此扩展板为所有的Arduino I/O引脚提供额外的连接器,也可以为通孔贴装和表面贴装的集成电路提供空间。总之,Ardiuno原型扩展板是您简化设计电路的快捷选择。电源
    The Proto Shield bring the power from the Arduino standard 5V and GND pins to the two power bus rows placed between the Through Hole package footprint, which can be used for powering the DIP sockets, or for power and ground rows.SPI connection
    The ICSP connector available on the shield hove his connections made directly to the SPI pins.
    • 1: (the one with the smal pointer sign) MISO connected to D12
    • 2: +5V
    • 3: SCK connected to D13
    • 4: MOSI connected to D11
    • 5: SS connected to D10
    • 6: GND
    Physical Characteristics
    The maximum length and width of the Proto Shield PCB are 2.7 and 2.1 inches respectively. Three screw holes allow the shield to be attached to a surface or case. Note that the distance between digital pins 7 and 8 is 160 mil (0.16"), not an even multiple of the 100 mil spacing of the other pins.
    下载连接:
    Arduino Proto扩展板电路
    Arduino Proto扩展板硬件设计文件
    GMT+8, 2024-11-27 08:45 , Processed in 0.101724 second(s), 15 queries , MemCache On.
