查看: 410|回复: 0
DM6446 数字视频评估模块
发表于 2012-8-14 11:51:54 | 显示全部楼层 |阅读模式
描述
数字视频评估模块让开发者可以建立对达芬奇处理器的即时评估,并开始构建数字视频应用,例如可视电话,车载信息娱乐系统,数码相机,媒体, IP机顶盒,视频安全监控系统和还没有被发明的数字视频产品。NOTE: You must register your DVEVM in order to access software updates and receive update notices. Register NowView the DVEVM in 3DThe Digital Video Evaluation Module (DVEVM) allows developers to write production-ready application code for the ARM and provides access to the DSP core using DaVinci APIs to begin immediate application development for the TMS320DM6443 and TMS320DM6446 digital media processors.The DVEVM includes TI’s eXpressDSP DM664x Linux DVSDK. The eXpressDSP Digital Video Software Development Kit allows DaVinci system integrators to incorporate discrete software modules and combine them into a single executable output for systems, avoiding months of tedious manual integration. By making it easy to create custom bundles of codecs for specific applications, the configuration kit makes it simple to reuse code.DVSDK software features:
  • TI video, imaging, speech and audio evaluation codecs
  • Custom codecs that comply with TI’s eXpressDSP™ Digital Media (xDM) algorithm standard
  • Demonstration versions of popular video codecs to enable developers to benchmark and evaluate performance parameters
  • Multimedia Application Programming Interfaces (APIs)
  • TI’s Codec Engine framework (Audio/Video)
  • DSP/BIOS™ real-time kernel
  • TI DSP/BIOS Link interprocessor communication technology (available in the Linux-based DVSDK)
  • MontaVista Pro Linux demonstration software
The TMDSADP1420 adapter is used for connecting TI and 3rd party XDS510 and XDS560- class emulators with a 14 pin native connector to the TMDSEVM6446 or customer boards with a compact (CTI) 20-pin header. The adapter improves signal integrity, translates voltages, and can optionally provide adaptive clocking.The hardware for the DM6446 Digital Video Evaluation Module (DSP13078U) and the DM6446 Digital Video Evaluation Module with European Power Cords (DSP13081U) differ slightly per the following:DM6446 Digital Video Evaluation Module - (DSP13078U)
  • TMS320DM446 DaVinci™ processor-based development board
  • NTSC video camera
  • NTSC LCD screen, speakers and microphone
  • IR remote
  • Hard disk drive (2.5-inch 40G)
DM6446 Digital Video Evaluation Module with European Power Cords - (DSP13081U)
  • PAL video camera
  • PAL LCD screen, speakers and microphone
  • IR remote
特性
The DVEVM is a complete out of box experience. The developer can turn on the board and hook up the included LCD screen. The board will boot MontaVista Linux and run a GUI that can be controlled by the included IR remote. The GUI includes access to three demos and the ability to run five different codec combinations.
The demos are:
Video and Audio decode
Video and Audio encode (uses included camera)
Simultaneous Video decode/encode
The five codec combos are:
R1.1.1H.264 Video Encode, H.264 Video Decode
R1.2.1H.264 (Baseline Profile) Video Encode, G.711 Speech Encode
R1.2.2MPEG-4 (Simple Profile) Video Encode, G.711 Speech Encode
R1.3.2MPEG2 Video Decode, MPEG1 Audio Decode
R1.3.1H.264 (Baseline Profile) Video Decode, AAC Audio Decode
R1.3.3MPEG-4 (Simple Profile) Video Decode, G.711 Speech Decode
These available demo codecs are on the DVEVM.
AAC+MPEG4
G7.11MPEG2
H.264
These codecs are available for production licensing from TI and will be on future development platforms.
WMV9WMA8
VC1MP3
JPEGG.728
AACG.723.1
WMA9G.729ab
包含项目
  • TMS320DM6446, DaVinci 数字媒体片上系统
  • Connectivity - CD-quality audio input and output
  • Connectivity - Daughter card connections to most peripheral interfaces
  • Connectivity - Multiple on-board memory types: CompactFlash, ATA, SD, DDR
  • Connectivity - USB 2.0, 10/100 EMAC
  • Connectivity - Video input via NTSC/PAL
  • Connectivity - Video output via NTSC/PAL and YPbPr/RGB
  • Hardware - Hard disk drive (2.5-inch 40G)
  • Hardware - IR remote
  • Hardware - LCD screen, speakers and microphone
  • Hardware - NTSC/PAL video camera
  • Hardware - TMS320DM446 DaVinci™ processor-based development board
  • Software - Codec Demos
  • Software - GNU Development Tools
  • Software - Multimedia APIs and Frameworks
  • Software - Preliminary Demo Version of MontaVista Linux 2.6.10
可用更新
Linux Software Updates Available for registered EVM users
  • Linux DM644x DVSDK production software is now available for registered users at www.ti.com/davincisoftwareupdates. Update your software now to take advantage of the MontaVistaPro v4.0.1 Demonstration software with MontaVista LSP 2.6.10 and TI’s xDAIS developers kit, Evaluation Codecs, Codec Engine, Digital Video Test Bench, DSPBIOS and BIOS Link, plus Demo applications.
NOTE: You must register your DVEVM in order to access software updates and receive update notices. Register NowWinCE Support and Customization for DM644x
  • Request Windows CE 5.0 SDK - Begin working with Windows CE 5.0 SDK at no charge, with support and customization available from select TI Authorized Software Providers (ASPs) or TI Windows CE Providers for a fee. The DM644x WinCE 5.0 SDK includes the BSP, OSAL (Operating System Adaptation Layer), Usage Examples, Demo and Documentation.
  • Customized Technical Support from Authorized Software Providers (APSs) and TI Windows CE Providers To speed development, TI also offers a robust portfolio of eXpressDSP™ digital media software, including the latest audio and video codecs, which can be obtained through TI ASPs. ASPs and Windows CE providers are also equipped to work directly with developers to provide additional services, customization and support. Get started today contact your ASP or TI Windows CE Provider.
  • Some ASPs may combine a baseline amount of support in an entry-level price for the SDK and application examples. Contact your ASP or TI Windows CE Provider for further details.
下载连接:
Booting DaVinci EVM from NAND Flash
GMT+8, 2024-11-27 08:42 , Processed in 0.109859 second(s), 15 queries , MemCache On.
