TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
入门工具包的 I/O扩展板给入门工具包和入门电路板用户提供了MCU 信号、 附加调试接头和 PICtail Plus 的子卡连接的完全访问权限。MCU 信号可用于附加原型电路或逻辑探测器监测信号。接头是为使用2-wire (ICSP)接口连接 JTAG 工具或微芯工具而提供的。A PIC32 Starter Kit (#DM320001), PIC32 USB Starter Kit II (#DM320003-2), PIC32 Ethernet Starter Kit (DM320004), dsPIC33E USB Starter Kit (DM330012),or a PIC24E USB Starter Kit(DM240012) is required for running application code as the I/O Expansion Board does not have an MCU.These starter kits can provide power to the I/O Expansion Board. The amount of power is determined by the drive capability of the USB port connected to the Starter Board's debugger at connector J1. If additional power is required, connect an optional 9V power supply (#AC16203) to the I/O Expansion Board.
下载连接:
入门工具包I/O 扩展板简介 |
