描述
智能电网基础设施评估模块基于OMAPL138/AM1808 主处理器, 有C2000 PLC接口功能, 以及单独出售的低功耗射频模块。This evaluation module is a development platform for smart grid infrastructure applications including data concentrator, power analytics, quality monitoring, circuit breakers, power protection, substation and power automation.
特性
Three-phase power system: Three current and voltage inputs plus neutral
- Isolation to prevent damage from high voltages and currents
- OMAP™-L138 processor: Integra™ DSP + ARM® for control, communications and signal processing. Full Linux® BSP supported by TI
- High-performance AIC provides 16-bit sampling at low SNR
- Supports control and data communications: Ethernet, PLC, <1-GHz RF, RS232, CAN
- Designed with best practices for high-speed systems: Good reference design for passing ESD system tests
包含项目
- Ethernet Cable
- Evaluation Board
- Power Supply
- Power Supply Cable
- SD Card (EVM Demo)
- Serial port cable
下载连接:
智能电网解决方案
SGI EVM 硬件手册 |
