查看: 335|回复: 0
STR9-COMSTICK开发评估板
  • 签到天数: 11 天
    发表于 2012-8-10 10:57:56 | 显示全部楼层 |阅读模式
    描述
     STR9-COMSTICK开发评估板是完整的、低成本的评价与开发软件包,提供快速并轻松介绍ARM™-M3 STM32 和 ARM966E®内核的微控制器系列的联网功能。The ComSticks include several sample applications implementing device peripherals (Ethernet, USB, CAN, ADC,...) plus a web server application so that users can explore networking of embedded applications. The C source code for all sample applications is provided so that users can modify them, and then rebuild and debug the application.The software package includes an unlimited Hitex toolchain tailored to the ComSticks.Software tools include an unlimited C compiler (TASKING for Cortex™-M3 and GNU for ARM) to build/rebuild the sample applications and Hitex HiTOP5 development environment for code editing, device programming and application debugging.For programming and debugging applications, the ComSticks connect to a host PC via a dedicated USB port. Application power is also provided via the USB connection with the host PC.
    关键特性
    • STM32-comStick with STM32F107VC and STR9-comStick with STR912FW
    • In-circuit debugging/programming via dedicated USB connector
    • Software package with
      • HiTOP IDE for programming and debugging
      • C compiler for Cortex™-M3 and ARM (no code size limit)
      • C source code for evaluation applications
      • STM32 and STR9 libraries from STMicroelectronics
      • Quick start and full documentation
      • Web links for updates, FAQs and information
    下载连接:
    STR9-COMSTICK开发评估板简介
    GMT+8, 2024-11-27 10:33 , Processed in 0.100771 second(s), 15 queries , MemCache On.
