TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
描述
STR750评估板(STR750-EVAL)是一个意法半导体基于 ARM ® 核的 STR75xF 微控制器完整的开发平台。基于一种经济高效、 灵活和开放的设计,它允许简单示范STR75xF 功能,快速评估了单片机的外围设备和其他功能。It includes the high performance STR750F microcontroller, which is based on the ARM7TDMI-S core and includes USB 2.0 compliant port with full speed data transmission, CAN 2.0A/B compliant interface, 3 UART channels, internal Flash and internal SRAM memory.The STR750-EVAL features a complete range of connectors and hardware features for developing applications based on STR75xF peripherals including motor control, USB and RS232 connectors, microphone, speaker, joystick, and LCD display.The STR750-EVAL uses a JTAG standard interface to connect to your host PC via any of a range of in-circuit emulators (ICE) for ARM core-based microcontrollers.
关键特性
- Three 5 V power supply options: power jack, USB connection or daughter board
- Real-time clock (RTC)
- Audio play and record
- 3 RS232 connectors, one with hardware flow control
- USB 2.0 compliant with full speed (12 Mb/s) data transmission
- CAN 2.0A/B connection
- Inductor motor control connector with 6 PWM output and emergency stop
- Debug and programming support via 20-pin JTAG connector
- Dot-matrix LCD module
- Joystick with 4-direction control and selector
- Extension connectors for daughter board or wrapping board
下载连接:
STR750-EVAL评估板简介
STR750-EVAL评估板用户指南 |
