查看: 363|回复: 0
STR7-SK/RAIS入门套件
  • 签到天数: 11 天
    发表于 2012-8-10 09:49:50 | 显示全部楼层 |阅读模式
    描述
    Raisonance REva入门套件是完整的并符合成本效益的解决方案,是针对开始意法半导体基于ARM® Cortex™- M3, ARM966E™和ARM7TDMI™内核微控制器的功能应用开发和评估而设计的。套件包含开发者开始设计应用的所有硬件和软件配置,主要组成包括REva评估板、微控制器、嵌入式RLink JTAG电路调试或编程器和Raisonance集成开发环境(RIDE)。The REva starter kits are available for a full range of 32-bit and 8-bit microcontrollers including the STM8, ST7 and uPSD families.
    关键特性
    • Raisonance software toolset with:
      • GNU C compiler
      • RIDE integrated development environment
      • High-level language debugger, editor, project manager and SIMICE simulator
      • RFlasher dedicated programming interface
    • Embedded RLink in-circuit debugger/programmer with USB interface to host PC and 20-pin JTAG application interface
    • Unlimited programming of the target device and debugging of up to 32 Kbytes of code in RAM or Flash memory
    • Interchangeable daughterboards featuring different target microcontrollers allowing development of applications for a wide range of ST microcontrollers
    • REva universal evaluation motherboard with:
      • One standard SO-DIMM connector to plug in interchangeable daughterboards.
      • Digital and analog I/O evaluation features, including on-board LEDs, buttons, switches, external analog connector, temperature sensor and potentiometer
      • I2C EEPROM and bus
      • RS232 driver and 2 DB9 connectors
      • Prototyping area
      • VDD settings for 1.8V, 3.3V and 5V
      • USB powered, no external power required
    下载连接:
    Raisonance REva入门套件简介
    GMT+8, 2024-11-27 10:34 , Processed in 0.113995 second(s), 15 queries , MemCache On.
