查看: 357|回复: 0
STM8A/128-EVAL评估板
  • 签到天数: 11 天
    发表于 2012-8-9 14:41:47 | 显示全部楼层 |阅读模式
    描述
    STM8Axx 评估板 STM8A/128-EVAL 旨在作为基于STM8内核STM8Axx 单片机全面的发展平台,带CAN2.0A/B兼容接口、I2C、 SPI,2个 UART通道,与智能卡,IrDA 和 LIN支持,内部 2Kbyte数据Flash和 128 Kbyte Flash 程序存储器、SWIM调试支持。The full range of hardware features helps you to evaluate all peripherals (including motor control, CAN, micro SD Card, smartcard, UART, LIN, IrDA) and develop your own applications. Extension headers make it possible to easily connect a daughterboard or wrapping board for your specific application.
    关键特性
    • Two 5 V power supply options: power jack or daughterboard
    • Audio play and record
    • 1 Gbyte or more micro SD Card™
    • Both A and B type smartcard support
    • 64 Kbit I2C EEPROM
    • 2 channels of RS-232 communication
    • IrDA transceiver
    • 2 channels of LIN communication
    • CAN2.0A/B compliant connection
    • Inductor motor control connector
    • SWIM and STice debug support
    • 122x32 dot-matrix serial interface LCD module
    • Joystick with 4-direction control and selector
    • Reset, Wakeup, Tamper and User button
    • 4 LEDs
    • Extension connector for daughterboard or wrapping board
    下载连接:
    STM8A/128-EVAL评估板简介
    STM8A/128-EVAL评估板用户指南
    GMT+8, 2024-11-27 10:29 , Processed in 0.113726 second(s), 15 queries , MemCache On.
