查看: 648|回复: 0
EK-LM3S9D90 以太网+OTG 评估套件
发表于 2012-8-6 09:32:32 | 显示全部楼层 |阅读模式
描述
Stellaris 评估套件提供了提供了一个低成本且有效的评估Stellaris 系列微控制器的途径。评估板的核心是独立的工具和 独立的Stellaris 系列器件。For kit-specific documentation and software, please refer to the individual kit links in the table below:
特性
LM3S9D90 Evaluation Kits (EK-LM3S9D90)
EKK-LM3S9D90EKI-LM3S9D90EKC-LM3S9D90EKT-LM3S9D90EKS-LM3S9D90
Keil ToolsIAR ToolsCodeSourcery ToolsCode Red Technologies ToolsCode Composer Studio Tools
Features an evaluation version of the Keil RealView Microcontroller Development Kit software tool.Features the IAR Embedded Workbench-KickStart edition, a 32 KB-limited evaluation version of the IAR Embedded Workbench.Features a 30-day evaluation version of CodeSourcery's SourceryG++ professional-quality GNU tool chain including optimized drivers for debug through serial wire debug.Features a 60-day evaluation version of Code Red Technologies tools.Features a board-locked, fully functional version of Code Composer Studio (CCStudio) Integrated Development Environment (IDE).
Kit OverviewThe Stellaris® LM3S9D90 Ethernet+USB-OTG Evaluation Kit provides a low-cost evaluation platform for the LM3S9D90 ARM® Cortex™-M3-based microcontroller. The kit includes two boards: the EK-LM3S9D90 evaluation board, and an In-Circuit Debug Interface (ICDI) board. The evaluation board features a simple, streamlined design for 32-bit Stellaris-based application with industrial connectivity, highlighting the Stellaris LM3S9D90 microcontroller's simultaneous integrated 10/100 Ethernet MAC/PHY, full-speed USB-OTG interfaces, and convenient connection to the MCU's GPIO ports.The Stellaris EK-LM3S9D90 Evaluation Board features:
  • Small form factor - just 36mm x 102mm
  • The Stellaris LM3S9D90 high-performance microcontroller with large memory
    • 32-bit ARM® Cortex-M3 core
    • 512 KB main Flash memory, 96 KB SRAM, and ROM loaded with StellarisWare® software
    • Integrated 10/100 Ethernet MAC/PHY, USB OTG, CAN, and low-power hibernation module
  • Ethernet 10/100 port with two LED indicators
  • USB 2.0 Full-Speed OTG port
  • Virtual serial communications port capability
  • Oversized board pads for GPIO access
  • Reset pushbutton and power LED
  • User pushbutton and LED
  • Detachable In-Circuit Debug Interface (ICDI) board can be used for programming and debugging other Stellaris Cortex-M3 boards
GMT+8, 2024-12-12 21:29 , Processed in 0.113412 second(s), 15 queries , MemCache On.
