查看: 1439|回复: 0
SH7211入门套件
发表于 2012-9-3 09:18:30 | 显示全部楼层 |阅读模式
SH7211入门套件是易于操作的SH7211微控制器入门和评估工具。The board also provides a useful platform for evaluating the Renesas suite of development tools for coding and debugging, using High-performance Embedded Workshop as well as programming the device using E10A emulator.The Renesas Starter Kit for SH7211 may be connected to the host PC using a simple RS232 serial connection or via the included USB E10A on chip debugging interface.The purpose of the board is to enable the user to evaluate the capabilities of the device and its peripherals by giving the user a simple platform on which code can be run only minutes from opening box. It can also prove an invaluable tool in development by providing a useful test platform for code already debugged using one of our more powerful emulation tools. Block Diagram
Layout and Specification
The LCD display module is supplied as a detachable sub-board. The board dimensions are 120 mm by 100 mm, detailed dimensions are available in the user manual.ItemSpecificationMicrocontrollerR5F72115D160FPVInput Clock10 MHzPotentiometerSingle-turn, 10 kΩLEDPower indicator: green x 1Boot indicator: orange x 1User: green x 1, orange x 1, red x 2SwitchReset x 1User/Boot x 1User x 2DC Power Jack5 V InputE10A Header14-pin box headerE8 Header14-pin box headerRS232 Serial Connector9-pin DSUBLCD Display Connector14-pin socketMicrocontroller Pin Header2.54 mm pitch, 36-pin x 4Application Board Interface2.54 mm pitch, 26-pin x 2 (JA1, JA2), 24-pin x 2 (JA5, JA6)BUS Interface Option2.54 mm pitch, 50-pin* Microcontroller Pin Header, Application Board Interface and BUS Interface Option are not contained in the product.* The potentiometer is fitted to offer an easy way of supplying a variable analog input to the controller. It does not necessarily reflect the accuracy of the controllers ADC. Please see the device manual for details.Manufacturer Name: PIHER INTERNATIONAL CORPORATIONPart Number: N6R (6 mm RoHS reflowable potentiometer) Configuration
  • CPU Board
  • Detachable LCD Display Module
  • Detachable AD Adjustment Shaft
  • E10A-USB for Starter Kit
  • Connection Cable (USB Cable, User Interface Cable)
  • Multi region 5 V power supply
  • Quick Start Guide
  • CD-ROM- Documents: User Manual, Tutorial, and more- IDE: High-performance Embedded Workshop- C/C++ Compiler: C/C++ Compiler Package for SuperH Family Evaluation Version- Debugger: E10A-USB Emulator Debugger
下载连接:
SH7211入门套件用户指南
SH7211入门套件快速入门指南
SH7211入门套件指导手册
GMT+8, 2024-11-26 23:36 , Processed in 0.136630 second(s), 15 queries , MemCache On.
