查看: 775|回复: 0
4DPi-35树莓派显示模块
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2015-4-20 11:10:35 | 显示全部楼层 |阅读模式
    所述4DPi-35是树莓派主显示器,尺寸3.5“(480x320),可直接插入树莓派的顶部,并显示通常发送到HDMI或复合输出的主输出。它有一个集成的电阻式触摸屏,使4DPi-35与树莓派实现功能,且无需鼠标。4DPi-35和树莓派之间的通信接口是由一个高速48兆赫SPI连接,它将一个板上处理器用于直接命令翻译和SPI通信压缩,并设有一个定制的DMA启用内核。该4DPi-35被设计用来与树莓派的Raspbian操作系统仪器运行,这是官方的树莓派操作系统。该4DPi-35设有一个分场头(P2),这使得当4DPi-35被连接时,所有的树莓派GPIO管脚都可被访问,这些都可以用跳线或IDC带状电缆接入。当树莓派断电时,这3.5“触摸屏可毫不费力地连接,一个单一的下载包可以让你运行几个简单的步骤。请参考数据的详细信息。特性:
    • Universal 3.5” Primary Display for the Raspberry Pi.
    • Compatible with Raspberry Pi A, B and B+ versions.
    • 480x320 QVGA Resolution, RGB 65K true to life colours, TFT Screen with integrated 4-wire Resistive Touch Panel.
    • Display full GUI output / primary output, just like a monitor connected to the Raspberry Pi
    • High Speed 48Mhz SPI connection to the Raspberry Pi, featuring SPI compression technology.
    • Powered directly off the Raspberry Pi, no external power supply is required.
    • Typical frame rate of 17FPS. Higher if image is able to be compressed by Kernel.
    • On/Off or PWM controlled backlight, selectable by on board jumper.
    • Module dimensions: 56.6 x 97.6 x 20.8mm (including corner plates). Weighing ~ 50g.
    • Display Viewing Area: 49 x 73.4mm
    • 4x corner plates with 2.6mm holes for mechanical mounting.
    • RoHS and CE Compliant.
    4DPi-35数据手册.pdf
    1.31 MB, 下载次数: 1
    GMT+8, 2024-11-25 14:34 , Processed in 0.114508 second(s), 16 queries , MemCache On.
