查看: 917|回复: 0
VEEK嵌入式影象评估套件
  • 签到天数: 11 天
    发表于 2012-7-30 10:24:59 | 显示全部楼层 |阅读模式
    多点触摸嵌入式影象评估套件是一个复杂的设计环境,它包含开发者对设计处理系统所需要的嵌入式器件。VEEK-MT是一个应用广泛集成开发嵌入式软件和硬件平台,包含硬件、设计工具、IP和参考设计。全面的集成开发板允许开发者快速的定义处理器和IP以适用相关特性的应用。 DE2-115开发板
        Cyclone IV EP4CE115 FPGA114,480 logic elements (LEs)432 M9K memory blocks3,888 Embedded memory (Kbits)266 Embedded 18 x 18 multipliers4 General-purpose PLLs528 User I/Os    配置EPCS64 serial configuration deviceOn-board USB-Blaster circuitryJTAG and AS mode configuration supported    存储设备128MB SDRAM2MB SRAM8MB FLASH with 8-bit mode32Kbit EEPROM    开关和指示灯18 switches and 4 Push-buttons18 red and 9 green LEDsEight 7-segment displays    音频24-bit encoder/decoder (CODEC)Line-in, line-out, and 3.5mm jacks    字符显示16x2 LCD module    板上时钟电路Three 50MHz oscillator clock inputsSMA connectors (external clock input/output)    SD卡插槽Provides SPI and 4-bit SD mode for SD card access    两个千兆以太网端口Integrated 10/100/1000 Ethernet    172引脚HSMCExtension for LCD and camera moduleConfigurable I/O standards (voltage levels: 3.3/2.5/1.8/1.5V)    USB Type A and BProvides host and device controller compliant with USB 2.0Support for data transfer at full-speed and low-speedPC driver available    40引脚扩展端口Configurable I/O standards (voltage levels: 3.3/2.5/1.8/1.5V)    VGA-out ConnectorVGA DAC (high speed triple DACs)    DB-9系列连接器RS-232 port with flow control    PS/2接口PS/2 connector for connecting a PS/2 mouse or keyboard   遥控器Infrared receiver module    电视接头TV decoder (NTSC/PAL/SECAM)    电源12V DC inputSwitching and step-down regulators LM3150MH 电容式液晶多点触摸屏
    7-inch TFT LCD with pixel resolution of 800*48016 million colors (8-bit RGB)LED backlight5万像素的数码图像传感器
    2,592H x 1,944V active pixels with Bayer color arrangementProgrammable frame rate up to 70FPS (VGA)Snapshot-mode mode to take frames on demandSimple two-wire serial control interface数字加速器
    Up to 13-bit resolution at +/- 16gSPI (3- and 4-wire) digital interfaceFlexible interrupts modes环境光传感器
    Precise illumination measurement under diverse lighting conditionsProgrammable interrupts16-bit digital output with I2C fast-mode at 400 kHzProgrammable analog gain and Integration time50/60Hz lighting ripple rejection
    VEEK嵌入式影象评估套件用户指南.pdf
    1.96 MB, 下载次数: 0
    GMT+8, 2024-12-5 03:17 , Processed in 0.118809 second(s), 16 queries , MemCache On.
