查看: 607|回复: 0
ADS2017momentum和cadence联合仿真报错
发表于 2019-7-29 15:11:02 | 显示全部楼层 |阅读模式
花了好久将cadence和momentum联合起来仿真,结果错误匪夷所思,请教各位大佬。
首先说一下环境
系统:虚拟机上的redhat6.4
cadence:6.1.7
ADS:2017
仿真报错
--- ERROR ---------------------------------------------------------------------
Tech Input proj.tch - line 1 : syntax error, unexpected TEXT, expecting UNITS.
Is VERSION a valid keyword and correctly spelled ?
The tech file should contain 3 blocks of data:
* the units definition, starting with the token UNITS
* the stack definition, starting with the token BEGIN_STACK
* the masks definition, starting with the token BEGIN_MASK
Unable to open the file proj.sub.
Check : - existence of file ;
        - file/directory read access permissions.
Unable to open the file proj.lmp.
查看过这个tch文件,不知道为啥把ltd里面的第一行也读进去了
就是第一行本来应该是UINTS,现在是TECHFORMAT=V2
GMT+8, 2025-1-22 19:13 , Processed in 0.106258 second(s), 15 queries , MemCache On.
