发表于 2019-7-29 14:59:31
显示全部楼层
请问一下楼主,在cadence调用momentum时一直报这个错怎么解决呢
Tech Input proj.tch - line 1 : syntax error, unexpected TEXT, expecting UNITS.
Is VERSION a valid keyword and correctly spelled ?
The tech file should contain 3 blocks of data:
* the units definition, starting with the token UNITS
* the stack definition, starting with the token BEGIN_STACK
* the masks definition, starting with the token BEGIN_MASK
--- ERROR ---------------------------------------------------------------------
Unable to open the file proj.sub.
Check : - existence of file ;
- file/directory read access permissions.
Unable to open the file proj.lmp.
查看了ltd文件和proj.sub,发现报错是第一行多了一个TECFORMAT=V2,这咋解决呢
