查看: 5538|回复: 5
小辉辉的STM32-Discovery官方资料分类【持续更新中】
  • 签到天数: 6 天
    发表于 2013-7-25 17:26:26 | 显示全部楼层 |阅读模式
    STM32F4的资料大部分都在这里:
    http://www.stmcu.org/download/index.php?act=ziliao&id=150
    根据个人的理解对这些资料作了一些规律,后期可能会增加一些个人的思维导图以增强理解。
    STM32F4-Discovery开发套件相关资料:
    索引:UM1472 User Manual
    标题:STM32F4DISCOVERY STM32F4 high-performance discovery board
    文档说明:STM32F4-DISCOVERY开发板资源介绍与使用说明
    链接:http://www.stmcu.org/download/index.php?act=down&id=3081
    推荐指数:★★★★
    索引:UM1467 User Manual
    标题:Getting started with software and firmware environments for the STM32F4DISCOVERY Kit
    文档说明:文档第一句话就很好地说明了一切:-)  This document describes the software, firmware environment and development recommendations required to build an application around the STM32F4DISCOVERY board.
    链接:http://www.stmcu.org/download/index.php?act=down&id=4906
    推荐指数:★★★★
    索引:AN3983 Application Note
    标题:STM32F4DISCOVERY peripheral firmware examples
    文档说明:STM32F4-DISCOVERY开发板外设例程Demo
    链接:http://www.stmcu.org/download/index.php?act=down&id=4904
    索引:AN3990 Application Note
    标题:Upgrading STM32F4DISCOVERY board firmware using a USB key
    文档说明:使用USB KEY对STM32F4-DISCOVERY进行固件升级,即通过IAP编程方式,从U盘中读取程序下载到STM32F4中。
    链接:http://www.stmcu.org/download/index.php?act=down&id=3069
    索引:AN3997 Application Note
    标题:Audio playback and recording using the STM32F4DISCOVERY
    文档说明:用STM32F4-Discovery做一个录音回放设备
    链接:http://www.stmcu.org/download/index.php?act=down&id=3068
    STM32F4 MCU相关资料:
    索引:PM0214 Programming Manual
    标题:STM32F3xxx and STM32F4xxx Cortex-M4 programming manual
    文档说明:STM32F4编程手册。This programming manual provides information for application and system-level software developers. It gives a full description of the STM32F3xxx and F4xxx CortexTM-M4 processor programming model, instruction set and core peripherals.
    链接:http://www.st.com/web/en/resource/technical/document/programming_manual/DM00046982.pdf
    推荐指数:★★★★
    索引:RM0090 Reference Manual
    标题:STM32F40x Reference Manual
    文档说明:典型的讲STM32F40x MCU的Datasheet。
    链接:http://www.st.com/web/en/resource/technical/document/reference_manual/DM00031020.pdf
    推荐指数:★★★★
    标题:STM32F405xx STM32F407xx Datasheet--Production data
    文档说明:This datasheet provides the description of the STM32F405xx and STM32F407xx lines of
    microcontrollers。即具体讲述405xx和407xx不同型号后缀的产品的具体配置。
    链接:http://www.stmcu.org/download/index.php?act=down&id=4654
    标题:Cortex-M4技术参考手册
    文档说明:讲Cortex-M4内核架构的
    链接:http://infocenter.arm.com/help/topic/com.arm.doc.ddi0439c/DDI0439C_cortex_m4_r0p1_trm.pdf
    推荐指数:★★★★
    STM32F4 MCU外设模块以及相关应用笔记:
    索引:PM0081 Programming Manual
    标题:STM32F40xxx and STM32F41xxx Flash programming manual
    文档说明:即In Application Programming。This programming manual describes how to program the Flash memory of STM32F405xx,STM32F407xx, STM32F415xx, and STM32F417xx microcontrollers. For convenience,these will be referred to as STM32F40x and STM32F41x, throughout the document unless otherwise specified.
    链接:http://www.st.com/web/en/resource/technical/document/programming_manual/DM00023388.pdf
    索引:AN2606 Application Note
    标题:STM32? microcontroller system memory boot mode
    文档说明:如题,即介绍STM32系统启动模式,与启动引导相关的还有:
    AN3965,AN3155,AN3968
    链接:http://www.stmcu.org/download/index.php?act=down&id=4568
    索引:AN3988 Application Note
    标题:Clock configuration tool for STM32F40x/41x microcontrollers
    文档说明:如题,配置F4时钟的
    链接:http://www.stmcu.org/download/index.php?act=down&id=3059
    索引:AN4013 Application Note
    标题:STM32F1xx, STM32F2xx, STM32F4xx, STM32L1xx timer overview
    文档说明:介绍定时器的
    链接:http://www.stmcu.org/download/index.php?act=down&id=4760
    索引:AN4044 Application Note
    标题:Using floating-point unit (FPU) with STM32F405/07xx and STM32F415/417xx microcontrollers
    文档说明:如题,介绍F4上面FPU的,对于需要用FPU的同学来说不可错过
    链接:http://www.stmcu.org/download/index.php?act=down&id=4919
    STM32中国,优酷站点
    http://i.youku.com/u/id_UNTM5NTAyMTky
    擦汗
    2016-7-28 09:42
  • 签到天数: 292 天
    发表于 2013-7-25 20:38:39 | 显示全部楼层
    好东西啊   要了
  • 签到天数: 656 天
    发表于 2013-7-25 22:35:54 | 显示全部楼层
    好贴要收藏
    无聊
    2016-12-20 15:08
  • 签到天数: 510 天
    发表于 2013-7-28 15:42:11 | 显示全部楼层
    很不错,新手的福音
  • 签到天数: 90 天
    [LV.6]常住居民II
    发表于 2013-8-18 14:25:11 | 显示全部楼层
    这个不错,楼主很用心整理的
  • 签到天数: 2193 天
    连续签到: 33 天
    [LV.Master]伴坛终老
    发表于 2014-3-2 09:59:52 | 显示全部楼层
    顶一个!!!!!!!!!!!!
    GMT+8, 2025-1-29 08:25 , Processed in 0.154846 second(s), 25 queries , MemCache On.
