查看: 2457|回复: 0
红外解码的液晶1602显示
  • 签到天数: 316 天
    发表于 2013-7-19 12:35:48 | 显示全部楼层 |阅读模式
            程序出了点问题请帮忙看一下:
    屏幕上显示的一直在闪烁,希望它能稳定的静态变化。。。
    #include"reg52.h"
    #include<intrins.h>//_nop_4微
    sbit RS = P2^4;   //定义端口
    sbit RW = P2^5;
    sbit EN = P2^6;
    #define RS_CLR RS=0
    #define RS_SET RS=1
    #define RW_CLR RW=0
    #define RW_SET RW=1
    #define EN_CLR EN=0
    #define EN_SET EN=1
    #define DataPort P0
    #define uchar unsigned char
    #define uint unsigned int
    void delay(uchar c)
        uchar a,b;
        for(a=110;a>0;a--)
            for(b=c;b>0;b--);
    uchar hwtime,jieshou_ok,chuli_ok;
    uchar code duanma[]="0123456789ABCDEF";
    uchar table[8];
    uchar hwleima[4];
    uchar hwweishu[33];
    /*******1602函数**************/
    void LCD_Write_Com(uchar com)
    delay(10) ;
    RS_CLR;
    RW_CLR;
    EN_SET;
    DataPort= com;
    _nop_();
    EN_CLR;
    void LCD_Write_Data(uchar Data)
    delay(10) ;
    RS_SET;
    RW_CLR;
    EN_SET;
    DataPort= Data;
    _nop_();
    EN_CLR;
    void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
    if (y == 0)
             LCD_Write_Com(0x80 + x);     //表示第一行
    else
            LCD_Write_Com(0xC0 + x);      //表示第二行
    while (*s)
    LCD_Write_Data( *s);
    s ++;
                    清屏函数
    void LCD_Clear(void)
    LCD_Write_Com(0x01);
    delay(10) ;
                  初始化函数
    void LCD_Init(void)
       LCD_Write_Com(0x38);    /*显示模式设置*/
       delay(10) ;
       delay(10) ;
       delay(10) ;
       LCD_Write_Com(0x08);    /*显示关闭*/
       LCD_Write_Com(0x01);    /*显示清屏*/
       LCD_Write_Com(0x06);    /*显示光标移动设置*/
       delay(10) ;
       LCD_Write_Com(0x0C);    /*显示开及光标设置*/
    void quchu()
             table[0]=duanma[hwleima[0]/16];
             table[1]=duanma[hwleima[0]%16];
             table[2]=duanma[hwleima[1]/16];
             table[3]=duanma[hwleima[1]%16];
             table[4]=duanma[hwleima[2]/16];
             table[5]=duanma[hwleima[2]%16];
             table[6]=duanma[hwleima[3]/16];
             table[7]=duanma[hwleima[3]%16];
            void display()
            static uchar i;
              quchu();
              LCD_Init();
              LCD_Clear();//清屏
              LCD_Write_Com(0xc0+1);
              for(i=0;i<8;i++)
               LCD_Write_Data(table[i]);
              LCD_Write_String(1,0,"hongwai jiema:");
    void time0() interrupt 1
    hwtime++;
    void time1() interrupt 3
    TH1=(65535-2000)/256;
    TL1=(65535-2000)%256;
    //display();
    void external() interrupt 0
       uchar starflag;
       static char i;//必须为静态成员
       if(starflag)
        if(hwtime<63&&hwtime>=33)
                i=0;
                        hwweishu[i]=hwtime;
                        hwtime=0;
                        i++;
                                if(i==33)
                           jieshou_ok=1;
                             i=0;
                 else           //必要的判断;舍弃错误的头码信号;重置
                    hwtime=0;
                    starflag=1;
            void itime0()
            EA=1;
            TMOD=0x02;
            TH0=0x00;
            TL0=0x00;
            ET0=1;
            TR0=1;
            void itime1()
            TMOD|=0x01;//很有必要
            ET1=1;
            TR1=1;
            EA=1;
            void iexternal()
            EX0=1;
            IT0=1;
            EA=1;
    void  chuli()
    uchar i,j;
    uchar k=1,dats,shuzhi;
    for(i=0;i<4;i++)
                    for(j=0;j<8;j++)//j值非常关键
                    dats=hwweishu[k];
                    if(dats>7)
                    shuzhi|=0x80;
                            if(j<7)//控制右移7次,0>>7=0x00;1>>7=0xff;
                            shuzhi>>=1;
                    k++;
                            hwleima[i]=shuzhi;
                            shuzhi=0;
    void main()
    itime0();
    itime1();
    iexternal();
    while(1)
    {                display();
                    if(jieshou_ok)
                    chuli();
                    jieshou_ok=0;
            if(chuli_ok)
            quchu();
    红外解码液晶显示.zip
    1.54 KB, 下载次数: 6
    解码程序
    GMT+8, 2025-1-24 14:38 , Processed in 0.111811 second(s), 16 queries , MemCache On.
