查看: 21563|回复: 5
[教程] 教你使用rpi-update轻松实现firmware更新!!!
  • 签到天数: 361 天
    发表于 2012-9-11 14:13:56 | 显示全部楼层 |阅读模式
    原帖由
    ukonline2000
      rpi-update是老外开发的一个更新树莓派firmware的工具,很方便也很好用,推荐给大家!
      红色部分是需要输入的:
      $ sudo apt-get update
      $ sudo apt-get install ca-certificates
      $ sudo apt-get install git-core
      $ sudo wget  -O /usr/bin/rpi-update
      $ sudo chmod +x /usr/bin/rpi-update
      $ sudo rpi-update
      Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS
      Performing self-update
      Autodetecting memory split
      Using ARM/GPU memory split of 192MB/64MB
      We're running for the first time
      Setting up firmware (this will take a few minutes)
      Using SoftFP libraries
      /opt/vc/sbin/vcfiled: error while loading shared libraries:libvchiq_arm.so: cannot open shared object file: No such file or directory
      If no errors appeared, your firmware was successfully setup
      A reboot is needed to activate the new firmware
      $ sudo ldconfig
      $ sudo rpi-update
      Updating firmware (this will take a few minutes)
      Your firmware is already up to date
      $ sudo reboot
    无聊
    2013-2-1 13:58
  • 签到天数: 9 天
    发表于 2012-9-17 14:40:40 | 显示全部楼层
    ,什么东东
  • 签到天数: 361 天
    发表于 2012-9-17 15:21:49 | 显示全部楼层
    rissa 发表于 2012-9-17 14:40
    ,什么东东
    恩.....这个还真不了解,只能请教作者本人了
  • 签到天数: 361 天
    发表于 2013-1-28 08:17:18 | 显示全部楼层
      $ sudo apt-get install ca-certificates[/backcolor ...
    谢谢powerdruy。下次一定不会了
  • 签到天数: 736 天
    发表于 2015-8-2 11:44:04 | 显示全部楼层
    更新口令
  • 签到天数: 736 天
    发表于 2015-10-10 22:11:23 | 显示全部楼层
    $sudo wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update
    --2015-10-10 22:09:40--  http://goo.gl/1BOfJ
    Resolving goo.gl (goo.gl)... 216.58.221.142, 2404:6800:4005:80b::200e
    Connecting to goo.gl (goo.gl)|216.58.221.142|:80... failed: Connection timed out.
    Connecting to goo.gl (goo.gl)|2404:6800:4005:80b::200e|:80... failed: Network is unreachable.
    GMT+8, 2025-1-16 01:48 , Processed in 0.152011 second(s), 24 queries , MemCache On.
