查看: 2122|回复: 0
一个用EDA做的时钟课程设计
    擦汗
    2014-8-15 09:55
  • 签到天数: 73 天
    [LV.6]常住居民II
    发表于 2013-7-7 17:58:23 | 显示全部楼层 |阅读模式
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_unsigned.all;
    entity shizhong is
    port( clk      :in std_logic;                       --系统时钟4M
          outm     ut std_logic_vector(6 downto 0);
          outm1    ut std_logic_vector(6 downto 0);
          outf    ut std_logic_vector(6 downto 0);
          outf1    ut std_logic_vector(6 downto 0);
          outs    ut std_logic_vector(6 downto 0);
          outs1    ut std_logic_vector(6 downto 0)
    end shizhong ;
    architecture miao of shizhong is
    signal seg0:std_logic_vector(3 downto 0);
    signal seg1:std_logic_vector(2 downto 0);
    signal seg2:std_logic_vector(3 downto 0);
    signal seg3:std_logic_vector(2 downto 0);
    signal seg4:std_logic_vector(3 downto 0);
    signal seg5:std_logic_vector(1 downto 0);
    begin
    process(clk)
    begin
    if clk'event and clk='1' then
        seg0<=seg0+'1';
        if (seg0="1001") then
        seg0<="0000";
        seg1<=seg1+'1';
       if (seg1="110") then
         seg1<="000";
         seg2<=seg2+'1';
          if (seg2="1001") then
          seg2<="0000";
          seg3<=seg3+'1';
           if (seg3="110") then
           seg3<="000";
           seg4<=seg4+'1';
            if (seg4="1001") then
            seg4<="0000";
            seg5<=seg5+'1';
            end if;
           end if;
          end if;
       end if;
        end if;
    end if;
    end process;
    process(clk)
    begin
       case seg0 is
         when "0000" =>outm<="1001111"; --0
         when "0001" =>outm<="0010010"; --1
         when "0010" =>outm<="0000110"; --2
         when "0011" =>outm<="1001100"; --3
         when "0100" =>outm<="0100100"; --4
         when "0101" =>outm<="0100000"; --5
         when "0110" =>outm<="0001111"; --6
         when "0111" =>outm<="0000000"; --7
         when "1000" =>outm<="0000100"; --8
         when "1001" =>outm<="0001000"; --9
         when others=>null;
       end case;
      end if;
    end process;
    process(clk)
    begin
       case seg1 is
         when "000" =>outm1<="1001111"; --0
         when "001" =>outm1<="0010010"; --1
         when "010" =>outm1<="0000110"; --2
         when "011" =>outm1<="1001100"; --3
         when "100" =>outm1<="0100100"; --4
         when "101" =>outm1<="0100000"; --5
         when "110" =>outm1<="0001111"; --6
       --  when "0111" =>outm<="0000000"; --7
        -- when "1000" =>outm<="0000100"; --8
        -- when "1001" =>outm<="0001000"; --9
         when others=>null;
       end case;
      end if;
    end process;
    process(clk)
    begin
       case seg2 is
         when "0000" =>outf<="1001111"; --0
         when "0001" =>outf<="0010010"; --1
         when "0010" =>outf<="0000110"; --2
         when "0011" =>outf<="1001100"; --3
         when "0100" =>outf<="0100100"; --4
         when "0101" =>outf<="0100000"; --5
         when "0110" =>outf<="0001111"; --6
         when "0111" =>outf<="0000000"; --7
         when "1000" =>outf<="0000100"; --8
         when "1001" =>outf<="0001000"; --9
         when others=>null;
       end case;
      end if;
    end process;
    process(clk)
    begin
       case seg3 is
         when "000" =>outf1<="1001111"; --0
         when "001" =>outf1<="0010010"; --1
         when "010" =>outf1<="0000110"; --2
         when "011" =>outf1<="1001100"; --3
         when "100" =>outf1<="0100100"; --4
         when "101" =>outf1<="0100000"; --5
         when "110" =>outf1<="0001111"; --6
       --  when "111" =>outf1<="0000000"; --7
       --  when "000" =>outf1<="0000100"; --8
       --  when "001" =>outf1<="0001000"; --9
         when others=>null;
       end case;
      end if;
    end process;
    process(clk)
    begin
       case seg4 is
         when "0000" =>outs<="1001111"; --0
         when "0001" =>outs<="0010010"; --1
         when "0010" =>outs<="0000110"; --2
         when "0011" =>outs<="1001100"; --3
         when "0100" =>outs<="0100100"; --4
         when "0101" =>outs<="0100000"; --5
         when "0110" =>outs<="0001111"; --6
         when "0111" =>outs<="0000000"; --7
         when "1000" =>outs<="0000100"; --8
         when "1001" =>outs<="0001000"; --9
         when others=>null;
       end case;
      end if;
    end process;
    process(clk)
    begin
       case seg5 is
         when "00" =>outs1<="1001111"; --0
         when "01" =>outs1<="0010010"; --1
         --when "0010" =>outs<="0000110"; --2
         --when "0011" =>outs<="1001100"; --3
         --when "0100" =>outs<="0100100"; --4
         --when "0101" =>outs<="0100000"; --5
         --when "0110" =>outs<="0001111"; --6
         --when "0111" =>outs<="0000000"; --7
         --when "1000" =>outs<="0000100"; --8
         --when "1001" =>outs<="0001000"; --9
         when others=>null;
       end case;
      end if;
    end process;
    end miao;
    GMT+8, 2024-11-25 08:16 , Processed in 0.118140 second(s), 15 queries , MemCache On.
