IEEE天线数据库1955-1956年
 楼主| 发表于 2013-7-29 09:40:08 | 显示全部楼层
回复:IEEE天线数据库1955-1956年
173.++Available+bandwidth+in+200-mile+VHF+tropospheric+propagation
173. Available bandwidth in 200-mile VHF tropospheric propagation.pdf
284.65 KB, 下载次数: 18
 楼主| 发表于 2013-7-29 09:41:22 | 显示全部楼层
174.++Antenna+Systems+in+the+Shipboard+Environment
174. Antenna Systems in the Shipboard Environment.pdf
325.68 KB, 下载次数: 19
 楼主| 发表于 2013-7-29 09:42:08 | 显示全部楼层
175.++Signal+Fluctuations+in+Long-Range+Overwater+Propagation
175. Signal Fluctuations in Long-Range Overwater Propagation.pdf
463.61 KB, 下载次数: 18
 楼主| 发表于 2013-7-29 09:42:52 | 显示全部楼层
176.++The+Reduction+of+Radio+Interference+in+Aeronautical+Communications+Systems
176. The Reduction of Radio Interference in Aeronautical Communications Systems.pdf
470.92 KB, 下载次数: 18
 楼主| 发表于 2013-7-29 09:43:33 | 显示全部楼层
177.++Definitions+of+'Bandwidth'+and+'Time+Duration'+of+Signals+Which+Are+Connected+by+an+Identit
177. Definitions of 'Bandwidth' and 'Time Duration' of Signals Which Are Connected by an Identit.pdf
249.62 KB, 下载次数: 18
 楼主| 发表于 2013-7-29 09:44:14 | 显示全部楼层
178.++Report+of+Advances+in+Microwave+Theory+and+Techniques-1954
178. Report of Advances in Microwave Theory and Techniques-1954.pdf
590.65 KB, 下载次数: 18
 楼主| 发表于 2013-7-29 09:44:53 | 显示全部楼层
179.++A+Broadband+Microstrip+Crystal+Mixer+with+Integral+DC+Return
179. A Broadband Microstrip Crystal Mixer with Integral DC Return.pdf
263.05 KB, 下载次数: 18
 楼主| 发表于 2013-7-29 09:45:56 | 显示全部楼层
180.++Slot+Array+Employing+Photoetched+Tri-Plate+Transmission+Lines
180. Slot Array Employing Photoetched Tri-Plate Transmission Lines.pdf
1.2 MB, 下载次数: 22
 楼主| 发表于 2013-7-31 09:02:44 | 显示全部楼层
182.++The+Mutual+and+Input+Impedance+of+Strips+Between+Parallel+Planes
182. The Mutual and Input Impedance of Strips Between Parallel Planes.pdf
351.79 KB, 下载次数: 19
 楼主| 发表于 2013-7-31 09:03:51 | 显示全部楼层
184.++Biography+-+George+Clark+Southworth
184. Biography - George Clark Southworth.pdf
164.78 KB, 下载次数: 18
GMT+8, 2025-2-3 02:40 , Processed in 0.187902 second(s), 32 queries , MemCache On.
