查看: 7351|回复: 4
[资料] 树莓派系统全面更新:Raspbian、Debian “wheezy”、Arch Linux
  • 签到天数: 1018 天
    发表于 2013-6-3 11:42:12 | 显示全部楼层 |阅读模式
    Raspbian “wheezy”
    If you’re just starting out, this is the image we recommend you use. It’s a reference root filesystem from Alex and Dom, based on the Raspbian optimised version of Debian, and containing LXDE, Midori, development tools and example source code for multimedia functions.
    Torrent
    Direct download
    SHA-1
    131f2810b1871a032dd6d1482dfba10964b43bd2
    Default login
    Username: pi Password: raspberry
    Soft-float Debian “wheezy”
    This image is identical to the Raspbian “wheezy” image, but uses the slower soft-float ABI. It is only intended for use with software such as the Oracle JVM which does not yet support the hard-float ABI used by Raspbian.
    Torrent
    Direct download
    SHA-1
    d42d913fb4f49b351ef865edcf318f47ae04edca
    Default login
    Arch Linux ARM
    Arch Linux ARM is based on Arch Linux, which aims for simplicity and full control to the end user. Note that this distribution may not be suitable for beginners. The latest version of this image uses the hard-float ABI, and boots to a command prompt in around ten seconds.
    Torrent
    Direct download
    SHA-1
    b30ba133a0a186023053f65513380d6b7f10759e
    Default login
    Username: root Password: root
  • 签到天数: 886 天
    发表于 2013-6-4 00:17:40 | 显示全部楼层
    沙发一个,立即升级!
    无聊
    2013-3-19 08:58
  • 签到天数: 2 天
    发表于 2013-6-4 07:13:38 | 显示全部楼层
    这个文件 “2013-05-29-wheezy-armel.zip”,解压后体重1.9GB,增大近一倍。
    不知道功能性能有否提升,尤其是GUI的速度增大的怎样。
    关键是它的firmware,因为不开源,普通用户只有被动接受。
    它的firmware,决定了RPi一百多万用户的感受。
    这个东东,是独立于Raspbian的吧?好像应该是硬件厂商鼓捣出来的。
    不知道这个firmware有没有进步,或者,进步有多大。
    如果它的firmware没有大的长进,Raspbian的升级没有多少意思。
    慵懒
    2013-8-12 17:47
  • 签到天数: 5 天
    发表于 2013-6-4 21:24:04 | 显示全部楼层
    关注一盘....
  • 签到天数: 5 天
    发表于 2013-6-4 23:04:44 | 显示全部楼层
    不知道功能性能有否提升,尤 ...
    所以其实在5月份北京的openSUSE发布交流会上,有工程师提到过:raspberry pi从开源硬件的角度来看其实是比较差的
    GMT+8, 2024-11-19 08:54 , Processed in 0.151264 second(s), 23 queries , MemCache On.
