查看: 4169|回复: 4
pcDuino运行LED strip driver
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2013-5-13 09:30:09 | 显示全部楼层 |阅读模式
    想在室内营造一点小氛围否,话说工程师工作繁忙也得自己造些情调不是。这我是在pcDuino上做的,接一个灯带驱动模块LED strip driver,链接文章里用的Arduino,附有程序代码,在pcDuino上点亮的话程序代码我也会附上的。为了使效果更好,LED灯带我设计的是呼吸灯哦!
    LED strip driver模块
    LED灯带(5m
    接线很简单,LED strip driver这里接了12V直流电源
    CLK --> pcDuino D2
    DIN --> pcDuino D3
    GND --> pcDuino GND
    打开ubuntu编译运行程序代码
    点亮后的5m灯带效果,这里是拍出来的照片灯带亮度逐渐变化的效果看不很明显,但是它是会“呼吸”的
    程序代码:
    1. #include "core.h"
    2. #define uint8_t unsigned char
    3. #define uint32_t unsigned long
    4. uint8_t Clkpin;
    5. uint8_t Datapin;
    6. void RGBdriver(uint8_t Clk, uint8_t Data)
    7. {
    8. Clkpin = Clk;
    9. Datapin = Data;
    10. pinMode(Datapin, OUTPUT);
    11. pinMode(Clkpin, OUTPUT);
    12. }
    13. void ClkRise(void)
    14. {
    15. digitalWrite(Clkpin, LOW);
    16. delayMicroseconds(1);
    17. digitalWrite(Clkpin, HIGH);
    18. delayMicroseconds(1);
    19. }
    20. void Send32Zero(void)
    21. {
    22. unsigned char i;
    23. for (i=0; i<32; i++)
    24. {
    25. digitalWrite(Datapin, LOW);
    26. ClkRise();
    27. }
    28. }
    29. void begin(void)
    30. {
    31. Send32Zero();
    32. }
    33. void end(void)
    34. {
    35. Send32Zero();
    36. }
    37. uint8_t TakeAntiCode(uint8_t dat)
    38. {
    39. uint8_t tmp = 0;
    40. if ((dat & 0x80) == 0)
    41. {
    42. tmp |= 0x02;
    43. }
    44. if ((dat & 0x40) == 0)
    45. {
    46. tmp |= 0x01;
    47. }
    48. return tmp;
    49. }
    50. // gray data
    51. void DatSend(uint32_t dx)
    52. {
    53. uint8_t i;
    54. for (i=0; i<32; i++)
    55. {
    56. if ((dx & 0x80000000) != 0)
    57. {
    58. digitalWrite(Datapin, HIGH);
    59. }
    60. else
    61. {
    62. digitalWrite(Datapin, LOW);
    63. }
    64. dx <<= 1;
    65. ClkRise();
    66. }
    67. }
    68. // Set color
    69. void SetColor(uint8_t Red,uint8_t Green,uint8_t Blue)
    70. {
    71. uint32_t dx = 0;
    72. dx |= (uint32_t)0x03 << 30; // highest two bits 1锛宖lag bits
    73. dx |= (uint32_t)TakeAntiCode(Blue) << 28;
    74. dx |= (uint32_t)TakeAntiCode(Green) << 26;
    75. dx |= (uint32_t)TakeAntiCode(Red) << 24;
    76. dx |= (uint32_t)Blue << 16;
    77. dx |= (uint32_t)Green << 8;
    78. dx |= Red;
    79. DatSend(dx);
    80. }
    81. void setup()
    82. {
    83. RGBdriver(2,3);
    84. }
    85. void loop()
    86. {
    87. unsigned int i;
    88. while(1)
    89. {
    90. for(i = 0;i < 256;i ++)
    91. {
    92. begin(); // begin
    93. SetColor(0,0,i); //Blue. First node data. SetColor(R,G,B)
    94. end();
    95. //delay(1);
    96. }
    97. for(i = 255;i > 0;i --)
    98. {
    99. begin(); // begin
    100. SetColor(0,0,i); //Blue. first node data
    101. end();
    102. //delay(1);
    103. }
    104. }
    105. }
    擦汗
    2014-2-12 10:49
  • 签到天数: 150 天
    [LV.7]常住居民III
    发表于 2013-5-13 09:37:57 | 显示全部楼层
    学习了。我知道接线是很简单的,可是接完了,脑子就大了
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
     楼主| 发表于 2013-5-13 10:25:15 | 显示全部楼层
    好吧 我附上LED strip driver的引脚示意图
    擦汗
    2014-2-12 10:49
  • 签到天数: 150 天
    [LV.7]常住居民III
    发表于 2013-5-14 09:20:49 | 显示全部楼层
    呵呵  谢谢!
  • 签到天数: 125 天
    [LV.7]常住居民III
    发表于 2013-5-17 00:52:43 | 显示全部楼层
    套件就是强大啊!
    GMT+8, 2025-1-20 19:29 , Processed in 0.147314 second(s), 23 queries , MemCache On.
