查看: 4248|回复: 2
【共享】 STR9开发板的详细资料
    擦汗
    2014-2-12 10:49
  • 签到天数: 150 天
    [LV.7]常住居民III
    发表于 2013-5-8 10:00:51 | 显示全部楼层 |阅读模式
    简介:
    Keil 公司的MCBSTR9 评估板适用于ST 公司的STR91xMCU 系列,用来产生和测试应用程 序,包括了单片STR9 系统的所有硬件元件,以开发目前和未来的产品。本文介绍了ST 公 司的STR91xFAxxx 主要特性,方框图以及MCBSTR9 评估板主要特性,方框图,技术数据和电路图。
    STR91xFAxxx : ARM966E-S? 16/32-bit Flash MCU with Ethernet, USB, CAN, AC motor control, 4 timers, ADC, RTC, DMA STR91xFA is a series of ARM-powered microcontrollers which combines a 16/32-bit ARM966E-S RISC processor core, dual-bank Flash memory, large SRAM for data or code, and a rich peripheral set to form an ideal embedded controller for a wide variety of applications such as point-of-sale terminals, industrial automation, security and surveillance, vending machines, communication gateways, serial protocol conversion, and medical equipment. The ARM966E-S core can perform single-cycle DSP instructions, good for speech processing, audio algorithms, and low-end imaging.
    The STR91xFA is a SiP device, comprised of two stacked die. One die is the ARM966E-S CPU with peripheral interfaces and analog functions, and the other die is the burst Flash. The two die are connected to each other by a custom high-speed 32-bit burst memory interface and a serial JTAG test/programming interface.
    STR91xFAxxx 主要特性:
    ■ 16/32-bit 96 MHz ARM9E based MCU
    – ARM966E-S RISC core: Harvard architecture, 5-stage pipeline, Tightly-Coupled Memories
    (SRAM and Flash)
    – STR91xFA implementation of core adds high-speed burst Flash memory interface, instruction
    prefetch queue, branch cache
    – Up to 96 MIPS directly from Flash memory
    – Single-cycle DSP instructions supported
    – Binary compatible with ARM7 code
    ■ Dual burst Flash memories, 32-bits wide
    – 256 KB/512 KB/1 MB/2 MB main Flash
    – 32 KB/128 KB secondary Flash
    – Sequential Burst operation up to 96 MHz
    – 100 K min erase cycles, 20 yr min retention
    ■ SRAM, 32-bits wide
    – 64K or 96K bytes, optional battery backup
    ■ 9 programmable DMA channels
    ■ Clock, reset, and supply management
    – Internal oscillator operating with external 4-25 MHz crystal
    – Internal PLL up to 96 MHz
    – Real-time clock provides calendar functions, tamper, and wake-up functions
    – Reset Supervisor monitors supply voltage, watchdog, wake-up unit, external reset
    – Brown-out monitor
    – Run, Idle, and Sleep Mode as low as 50 uA
    ■ Vectored interrupt controller (VIC)
    – 32 IRQ vectors, 30 interrupt pins
    – Branch cache minimizes interrupt latency
    ■ 8-channel, 10-bit A/D converter (ADC)
    – 0 to 3.6 V range, 0.7 usec conversion
    ■ 10 Communication interfaces
    – 10/100 Ethernet MAC with DMA and MII
    – USB Full-speed (12 Mbps) slave device
    – CAN interface (2.0B Active)
    – 3 16550-style UARTs with IrDA protocol
    – 2 Fast I2C?, 400 kHz
    – 2 channels for SPI?, SSI?, or MICROWIRE?
    ■ External Memory Interface (EMI)
    – 8- or 16-bit data, up to 24-bit addressing
    – Static Async modes for LQFP128
    – Additional burst synchronous modes for LFBGA144
    ■ Up to 80 I/O pins (muxed with interfaces)
    ■ 16-bit standard timers (TIM)
    – 4 timers each with 2 input capture, 2 output compare, PWM and pulse count modes
    ■ 3-Phase induction motor controller (IMC)
    ■ JTAG interface with boundary scan
    ■ Embedded trace module (ARM ETM9)
    电路图:
    STR9英文.pdf (1.16 MB, 下载次数: 10)
    评分
    参与人数 1声望 +1 与非币 +3 收起 理由
    小菜儿 + 1 + 3
    查看全部评分
  • 签到天数: 361 天
    发表于 2013-5-8 10:27:50 | 显示全部楼层
    飘过。顶一下吧
    擦汗
    2014-2-12 10:49
  • 签到天数: 150 天
    [LV.7]常住居民III
     楼主| 发表于 2013-5-9 08:42:45 | 显示全部楼层
    GY@艳 发表于 2013-5-8 10:27
    飘过。顶一下吧
    呵呵呵  谢谢喽!
    GMT+8, 2025-1-11 08:18 , Processed in 0.155396 second(s), 24 queries , MemCache On.
