查看: 2072|回复: 1
3根线驱动12864
  • 签到天数: 361 天
    发表于 2012-9-4 15:18:25 | 显示全部楼层 |阅读模式
    3根线驱动12864
    #include <MSP430G2553.h>
    #include "lcd12864.h"
    uint i;
    uchar Table1[]="频率跟踪系统";
    uchar Table2[]="频率:";
    uchar Table3[]="Hz";
    void main(void)
    WDTCTL = WDTPW + WDTHOLD;
    init();
    while(1)
    display_char(Table1,0,1);
    delay(15);
    display_char(Table2,1,0);
    delay(15);
    display_char(Table3,1,7);
    #ifndef lcd12864_H_
    #define lcd12864_H_
    # include<MSP430G2553.h>
    #define uchar unsigned char
    #define uint unsigned int
    #define CS_H P2OUT|=BIT0 //P10 cs
    #define CS_L P2OUT&=~BIT0
    #define SCLK_H P2OUT|=BIT1 //P11 sclk
    #define SCLK_L P2OUT&=~BIT1
    #define SID_H P2OUT|=BIT2 //P12 SID
    #define SID_L P2OUT&=~BIT2
    void init();
    void delay(uint);
    void sendbyte(uchar);
    void write_com(uchar); //写指令
    void write_dat(uchar); //写数据
    void lcd_pos(uchar X,uchar Y);//确定位置
    void display(uint);
    void display_char(uchar *,uchar,uchar);
    void go (uint);
    uchar pos;
    if (X==0)
    {X=0x80;}
    else if (X==1)
    {X=0x90;}
    else if (X==2)
    {X=0x88;}
    else if (X==3)
    {X=0x98;}
    pos = X+Y ;
    write_com(pos); //显示地址
    void init()
    delay(2);
    write_com(0x30); //30--基本指令动作
    delay(5);
    write_com(0x0c); //光标右移画面不动
    delay(5);
    write_com(0x01); //清屏
    delay(5); //清屏时间较长
    write_com(0x06); //显示打开,光标开,反白关
    delay(5);
    void delay(uint z)
    uint x,y;
    for(x=z;x>0;x--)
    for(y=110;y>0;y--);
    void sendbyte(uchar zdata)
    unsigned int i;
    for(i=0; i<8; i++)
    P2DIR=0xff;
    if((zdata << i) & 0x80)
    SID_H;
    else
    SID_L;
    SCLK_L;
    SCLK_H;
    void write_com(uchar cmdcode)
    { P2DIR=0xff;
    CS_H;
    sendbyte(0xf8);
    sendbyte(cmdcode & 0xf0);
    sendbyte((cmdcode << 4) & 0xf0);
    delay(2);
    void write_dat(uchar Dispdata)
    { P2DIR=0xff;
    CS_H;
    sendbyte(0xfa);
    sendbyte(Dispdata & 0xf0);
    sendbyte((Dispdata << 4) & 0xf0);
    delay(2);
    void display(uint num)
    uchar qian,bai,shi,ge;
    qian=num/1000;
    bai=num%1000/100;
    shi=num%1000%100/10;
    ge=num%10;
    write_dat(0x30+qian);
    write_dat(0x30+bai);
    write_dat(0x30+shi);
    write_dat(0x30+ge);
    void display_char(uchar * pointer,uchar X,uchar Y)
    lcd_pos(X,Y);
    while(*pointer!='\0')
    write_dat(*pointer);
    pointer++;
    #endif /* lcd12864_H_ */
  • 签到天数: 692 天
    发表于 2012-9-4 18:39:18 | 显示全部楼层
    楼主很给力,顶一下!
    GMT+8, 2024-11-8 23:55 , Processed in 0.131088 second(s), 17 queries , MemCache On.
