查看: 5370|回复: 9
[项目] MSP430红外接收和发送代码,已经试验过,OK
    无聊
    2016-12-23 14:05
  • 签到天数: 7 天
    发表于 2013-5-7 16:51:31 | 显示全部楼层 |阅读模式
    #include "msp430f5309.h"
    #include "Sys_clk/sys_clk.h"
    unsigned char j;
    unsigned char irda_receive_data;
    void irda_gpio_init(void)
      //发射引脚
      P1DIR |= BIT5;
      P1SEL &= ~BIT5;
      P1OUT |= BIT5;
      P1DS |= BIT5;
      //接受引脚
      P1SEL &= ~BIT6;
      P1DIR &= ~BIT6;
      P1IE |= BIT6;
      P1IES |= BIT6;
    //产生38KHZ的高电平
    void timer_a1_init(void)
      TA1CTL |= TASSEL__SMCLK + MC__STOP  + TACLR + ID_2 ;
      //TA1CCTL0 |= CCIE;
      //TA1CCR0 = 0;
    void timer_a2_init(void)
      TA2CTL |= TASSEL__SMCLK + MC__STOP + TACLR + ID_2 ;
      //TA2CCTL0 |= CCIE;
      //TA2CCR0 = 0;
    void irda_send_char(unsigned char irda_send_data)
      unsigned char i;
      //9ms的高电平
      TA1CTL |= MC__UP;
      TA1CCTL0 |= CCIE;
      TA1CCR0 = 52;
      TA2CTL |= MC__UP;
      TA2CCTL0 |= CCIE;
      TA2CCR0 = 36000;
      j = 1;
      while(j);
      j = 1;
      TA1CTL |= MC__STOP;
      TA1CCTL0 &= ~CCIE;
      //4ms的低电平
      TA2CCR0 = 16000;
      P1OUT |= BIT5;
      j = 1;
      while(j);
      j = 1;
      for(i=0;i<8;i++)
        //0.5ms的高电平
        TA1CTL |= MC__UP;
        TA1CCTL0 |= CCIE;
        //TA1CCR0 = 52;
        TA2CCR0 = 2000;
        while(j);
        j = 1;
        TA1CTL |= MC__STOP;
        TA1CCTL0 &= ~CCIE;
        P1OUT |= BIT5;
        if(irda_send_data&0x80)
          //TA2CTL |= MC__UP;
          TA2CCR0 = 6000;
          while(j);
          j = 1;
        else
          //TA2CTL |= MC__UP;
          TA2CCR0 = 2000;
          while(j);
          j = 1;
        irda_send_data <<= 1;
      TA2CCTL0 &= ~CCIE;
      TA2CTL |= MC__STOP;
      //结束标志
      //高电平
      TA1CTL |= MC__UP;
      TA1CCTL0 |= CCIE;
      TA2CTL |= MC__UP;
      TA2CCTL0 |= CCIE;
      TA2CCR0 = 10000;
      //TA2CCR0 = 5000;
      j = 1;
      while(j);
      j = 1;
      TA1CTL |= MC__STOP;
      TA1CCTL0 &= ~CCIE;
      TA2CCTL0 &= ~CCIE;
      TA2CTL |= MC__STOP + TACLR;
      P1OUT |= BIT5;
    void irda_send_char_test(unsigned char irda_send_data)
      unsigned char i;
      j = 1;
      //9ms的高电平
      P1OUT &= ~BIT5;
      TA2CTL |= MC__UP;
      TA2CCTL0 |= CCIE;
      TA2CCR0 = 36000;
      while(j);
      j = 1;
      //4ms的低电平
      TA2CCR0 = 16000;
      P1OUT |= BIT5;
      while(j);
      j = 1;
      for(i=0;i<8;i++)
        //0.5ms的高电平
        P1OUT &= ~BIT5;
        //TA1CCR0 = 52;
        TA2CCR0 = 2000;
        while(j);
        j = 1;
        P1OUT |= BIT5;
          //TA2CTL |= MC__UP;
          TA2CCR0 = 6000;
          while(j);
          j = 1;
        else
          //TA2CTL |= MC__UP;
          TA2CCR0 = 2000;
          while(j);
          j = 1;
      TA2CCTL0 &= ~CCIE;
      TA2CTL |= MC__STOP;
      //结束标志
      //9ms的高电平
      TA1CTL |= MC__UP;
      TA1CCTL0 |= CCIE;
      TA2CTL |= MC__UP;
      TA2CCTL0 |= CCIE;
      TA2CCR0 = 10000;
      j = 1;
      while(j);
      j = 1;
      TA1CTL |= MC__STOP;
      TA1CCTL0 &= ~CCIE;
      TA2CCTL0 &= ~CCIE;
      P1OUT |= BIT5;
    void USCIA1_ByteSend(unsigned char SendData)
      while (!(UCA1IFG&UCTXIFG));            // USCI_A3 TX buffer ready?
      UCA1TXBUF = SendData;                  // TX -> RXed character
    void irda_receive(void)
      //检测先导码
      unsigned int low_v_time,high_v_time,i;
      P1IE &= ~BIT6;
      TA1CTL |= MC__UP;
      TA1CCTL0 |= CCIE;
      TA1CTL |= TACLR;
      TA1CCR0 = 50000;
      while(!(P1IN&BIT6))
         if(TA1R > 49000)
          break;
      low_v_time = TA1R;
      TA1CTL |= MC__STOP;
      TA1CCTL0 &= ~CCIE;
      TA1CTL |= TACLR;
      TA1CTL |= MC__UP;
      TA1CCTL0 |= CCIE;
      while((P1IN&BIT6))
         if(TA1R > 49000)
          break;
      high_v_time = TA1R;
      TA1CTL |= MC__STOP;
      TA1CCTL0 &= ~CCIE;
      //TA1CTL |= TACLR;
      if((high_v_time>10000)&&(high_v_time<20000)&&(low_v_time<40000)&&(low_v_time>25000))
        for(i=0;i<8;i++)
          irda_receive_data <<= 1;
          while(!(P1IN&BIT6))
         if(TA1R > 49000)
          break;
          TA1CTL |= TACLR;
          TA1CTL |= MC__UP;
          TA1CCTL0 |= CCIE;
          while((P1IN&BIT6))
         if(TA1R > 49000)
          break;
          high_v_time = TA1R;
          if(high_v_time>4000)
            irda_receive_data |= 0x01;
        USCIA1_ByteSend(irda_receive_data);
      P1IE |= BIT6;
    void irda_send_string(unsigned char *ptr,unsigned char length)
      unsigned int k;
      while(length>0)
        irda_send_char(*ptr);
        ptr++;
        length--;
        k = 10000;
        while(k--);
    void uart_init(void)
      P4SEL |= BIT4 | BIT5;                     // P3.3,4 = USCI_A0 TXD/RXD
      UCA1CTL1 |= UCSWRST;                      // **Put state machine in reset**
      UCA1CTL1 |= UCSSEL_2;                     // SMCLK
      //UCA1BR0 = 18;
      UCA1BR0 = 139;                              // 1MHz 115200 (see User's Guide)
      UCA1BR1 = 0;                              // 1MHz 115200
      UCA1MCTL |= UCBRS_1 | UCBRF_0;            // Modulation UCBRSx=1, UCBRFx=0
      UCA1CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
      //UCA1IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
    int main( void )
      // Stop watchdog timer to prevent time out reset
      int k;
      unsigned char irda_sen_string[11] = "12345678abc";
      WDTCTL = WDTPW + WDTHOLD;
      //P1DIR |= BIT0;
      set_sys_clk();
      irda_gpio_init();
      uart_init();
      USCIA1_ByteSend('a');
      timer_a1_init();
      timer_a2_init();
      __bis_SR_register(GIE);
      while(1)
        //   while(!(UCA1IFG&UCRXIFG));
        //     P1IE &= ~BIT6;
        //    irda_sen_string[i] = UCA1RXBUF;
        //    uart_rx_data = UCA1RXBUF;
        //      irda_send_char(UCA1RXBUF);
        //  while(1)
        //irda_send_char(uart_rx_data);
        //    irda_send_char(0x32);
        //按键发射
        while(P1IN&BIT0);
        //P1IE &= ~BIT6;
        irda_send_string((unsigned char *)irda_sen_string,11);
        k = 10000;
        while(k--);
        //P1IE |= BIT6;
    #pragma vector = TIMER1_A0_VECTOR
    __interrupt void TIMERA1_A0_INT()
      P1OUT ^= BIT5;
    #pragma vector = TIMER2_A0_VECTOR
    __interrupt void TIMERA2_A0_INT()
      j = 0;
    #pragma vector = PORT1_VECTOR
    __interrupt void PORT1_INT()
      irda_receive();
  • 签到天数: 647 天
    发表于 2013-5-7 19:42:49 | 显示全部楼层
    谢谢楼主分享!
  • 签到天数: 853 天
    发表于 2013-5-7 22:23:26 | 显示全部楼层
    多谢分享啦!!就下次直接弄个文件吧。。这样好下载
    无聊
    2015-12-14 11:43
  • 签到天数: 556 天
    发表于 2013-5-7 22:25:18 | 显示全部楼层
    顶一个
  • 签到天数: 3747 天
    连续签到: 60 天
    [LV.Master]伴坛终老
    发表于 2013-5-8 09:19:53 | 显示全部楼层
    不错,顶1
  • 签到天数: 205 天
    [LV.7]常住居民III
    发表于 2013-5-13 01:18:24 | 显示全部楼层
    楼主太牛了。。。。
  • 签到天数: 340 天
    发表于 2013-5-16 07:53:39 | 显示全部楼层
    lz最近在搞什么研究呢??
    11 小时前
  • 签到天数: 4089 天
    连续签到: 44 天
    [LV.Master]伴坛终老
    发表于 2013-8-13 22:23:45 | 显示全部楼层
    不错!有空实验一下。
  • 签到天数: 1730 天
    [LV.Master]伴坛终老
    发表于 2013-8-15 14:33:22 | 显示全部楼层
    收藏备用。
  • 签到天数: 371 天
    连续签到: 2 天
    发表于 2013-8-16 09:46:53 | 显示全部楼层
    不错~有空试一下
    GMT+8, 2025-1-20 21:54 , Processed in 0.201735 second(s), 33 queries , MemCache On.
