又找到一个 ams 芯片的资料~~这么翻译下去,coco的英文水平要飚升了~~
这位楼主分享了自己的代码,表示自己是编程渣,希望有人可以帮助他 编程……
一楼提供的资料是那位楼主自己编写的程序(不知道是否有错),2楼的程序是一位热心网友提供的~(应该没错~~)
Hey people!
I'm trying to connect a AS5050 / AS5055 Magnetic Rotary Encoder to my arduino mega but I must admit I'm not a programming guy!
So I was wondering if someone could give me some help writing the code...?
This is the code in C... does anyone has a "arduino" translation
- * Reads out chip data via SPI interface
- * This function is used to read out cordic value from chips supporting SPI
- * interface.
- #define SPI_CMD_READ 0x8000 /*!< flag indicating read attempt when using SPI interface */
- #define SPI_REG_DATA 0x7ffe /*!< data register when using SPI */
- #define SPI_REG_AGC 0x7ff0 /*!< agc register when using SPI */
- #define SPI_REG_CLRERR 0x6700 /*!< clear error register when using SPI */
- void spiReadData()
- u16 dat; // 16-bit data buffer for SPI communication
- ushort angle, agcreg;
- ubyte agc;
- ushort value;
- bit alarmHi, alarmLo;
- /* Send READ AGC command. Received data is thrown away: this data comes from the precedent
- command (unknown)*/
- dat = SPI_CMD_READ | SPI_REG_AGC;
- dat |= spiCalcEvenParity(dat);
- spiTransfer((u8*)&dat, sizeof(u16));
- /* Send READ ANGLE command. Received data is the AGC value, from the precedent command */
- dat = SPI_CMD_READ | SPI_REG_DATA;
- agcreg = dat;
- /* Send NOP command. Received data is the ANGLE value, from the precedent command */
- dat = 0x0000; // NOP command.
- angle = dat >> 2;
- if (((dat >> 1) & 0x1) || ((agcreg >> 1) & 0x1))
- /* error flag set - need to reset it */
- dat = SPI_CMD_READ | SPI_REG_CLRERR;
- else
- agc = (agcreg >> 2) & 0x3f; // AGC value (0..63)
- value = (dat >> 2) & 0x3fff; // Angle value (0..4095 for AS5055)
- angle = (value * 360) / 4095; // Angle value in degree (0..359.9°)
- alarmLo = (dat >> 14) & 0x1;
- alarmHi = (dat >> 15) & 0x1;
- * Calculate even parity of a 16 bit unsigned integer
- * This function is used by the SPI interface to calculate the even parity
- * of the data which will be sent via SPI to the encoder.
- * \param[in] value : 16 bit unsigned integer whose parity shall be calculated
- * \return : Even parity
- static u8 spiCalcEvenParity(ushort value)
- u8 cnt = 0;
- u8 i;
- for (i = 0; i < 16; i++)
- if (value & 0x1)
- cnt++;
- value >>= 1;
- return cnt & 0x1;
