查看: 5261|回复: 4
STM32的串口配置(中断方式)
  • 签到天数: 222 天
    [LV.7]常住居民III
    发表于 2013-4-22 09:19:24 | 显示全部楼层 |阅读模式
    STM32的串口中断配置,也是很简单的.
        首先是配置UART的GPIO口
        首先是配置UART的GPIO口
        * Name : UART1_GPIO_Configuration
        * Deion : Configures the uart1 GPIO ports.
        * Input : None
        * Output : None
        * Return : None
        void UART1_GPIO_Configuration(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        // Configure USART1_Tx as alternate push-pull
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        // Configure USART1_Rx as input floating
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        然后是配置串口参数
        * Name : UART1_Configuration
        * Input : None
        * Output : None
        * Return : None
        void USART_Configuration(void)
        USART_InitTypeDef USART_InitStructure;
        USART_ClockInitTypeDef USART_ClockInitStructure;
        Uart1_GPIO_Configuration();
        USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
        USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
        USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
        USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
        /* Configure the USART1 synchronous paramters */
        USART_ClockInit(USART1, &USART_ClockInitStructure);
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        /* Configure USART1 basic and asynchronous paramters */
        USART_Init(USART1, &USART_InitStructure);
        /* Enable USART1 Receive interrupts */
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        /* Enable USART1 */
        USART_Cmd(USART1, ENABLE);
        然后是在中断设置,需要修改stm32f10x_it.c 中的串口中断函数 并且需要修改void NVIC_Configuration(void)函数
        修改NVIC_Configuration函数
        * Name : NVIC_Configuration
        * Deion : Configures NVIC and Vector Table base location.
        * Input : None
        * Output : None
        * Return : None
        NVIC_InitTypeDef NVIC_InitStructure;
        #ifdef VECT_TAB_RAM
        /* Set the Vector Table base location at 0x20000000 */
        NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
        #else /* VECT_TAB_FLASH */
        /* Set the Vector Table base location at 0x08000000 */
        NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
        #endif
        /* Configure the NVIC Preemption Priority Bits */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        /* Enable the USART1 Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        //串口中断
        void USART1_IRQHandler(void)
        //处理接收到的数据
        if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        /* Clear the USART1 Receive interrupt */
        USART_ClearITPendingBit(USART1, USART_IT_RXNE);
        //发送中断
        if (USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
        USART_SendData(USART1, Send_Data[Send_Length++]);
        if (Send_Length==SEND_LENGTH)
        //发送字节结束
        USART_ClearITPendingBit(USART1,USART_IT_TXE);
        USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
        USART_ITConfig(USART1, USART_IT_TC, ENABLE);
        //发送完成
        if (USART_GetITStatus(USART1, USART_IT_TC) != RESET)
        USART_ClearITPendingBit(USART1,USART_IT_TC);
        USART_ITConfig(USART1, USART_IT_TC, DISABLE);
        在需要发送的程序里Send_Data[SEND_LENGTH]和发送长度设置好,
        void Send_to_PC(void)
        //设置好Send_Data[SEND_LENGTH]数组
        //打开发送中断
        USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
        至此 串口就可以工作起来了!~
  • 签到天数: 980 天
    发表于 2013-4-22 10:50:08 | 显示全部楼层
    {:soso_e100:}
    慵懒
    2019-7-13 19:58
  • 签到天数: 1818 天
    [LV.Master]伴坛终老
    发表于 2013-4-23 08:49:14 | 显示全部楼层
    很好,抽空试一下
  • 签到天数: 943 天
    发表于 2014-9-19 15:13:29 | 显示全部楼层
    很好    学习啦
  • 签到天数: 409 天
    发表于 2014-9-19 16:04:56 | 显示全部楼层
    看看,谢谢了~
    GMT+8, 2025-1-12 08:54 , Processed in 0.146456 second(s), 23 queries , MemCache On.
