查看: 4331|回复: 2
基于AVR XMEGA-A3BU Xplained控制器的Wifi小车制作(7)---小试牛刀
    擦汗
    2024-9-30 02:33
  • 签到天数: 444 天
    发表于 2013-4-10 23:55:16 | 显示全部楼层 |阅读模式
          今晚抽空做了下    Atmel XMEGA-A3BU Xplained评估板评测(二)
    https://www.cirmall.com/evaluation/xmega-a3bu-xplained-%e8%af%84%e6%b5%8b%ef%bc%88%e4%ba%8c%ef%bc%89/    里面的例子
          熟悉了下 Atmel Studio 6.0  编程的方式,发现真的跟官方所说是一样子的,  ASF 用于单片机编程很爽。很多底层的驱动软件不用自己去编写,可以直接调用。
    Atmel Software Framework框架,进一步简化了开发流程,缩短了开发周期。
          视频上传出我拍的视频
             今晚抽空打开了 Atmel Studio 想看看ASF是如何定义一些操作的,吃了一惊:
    首先看让LED灯闪的代码
    #include <asf.h>
    int main (void)
    board_init();
    sysclk_init();//调用ASF框架函数初始化时钟
    delay_init(sysclk_get_cpu_hz());//调用ASF框架函数初始化delay服务
    while(1)
      delay_ms(500); //调用ASF框架函数延时500Ms
      gpio_set_pin_low(LED0);
      gpio_set_pin_low(LED1);
      delay_ms(500);//调用ASF框架函数延时500Ms
      gpio_set_pin_high(LED0);
      gpio_set_pin_high(LED1);
    前面的初始化函数  init()很好理解,然后就是 gpio_set_pin_low(LED0);gpio_set_pin_high(LED0);  这两句让LED0的I/O端口置1、置0 实现闪亮。
    很显然,点开asf.h
    #ifndef ASF_H
    #define ASF_H
    #include <ccp.h>
    #include <xmega_reset_cause.h>
    #include <delay.h>
    #include <gpio.h>
    #include <board.h>
    #include <ioport.h>
    #include <interrupt.h>
    #include <nvm.h>
    #include <parts.h>
    #include <sysclk.h>
    #include <compiler.h>
    #include <status_codes.h>
    #endif
    又是include 许多的头文件!
    打开xmega_reset_cause.h   找到
    #define LED0_GPIO                       IOPORT_CREATE_PIN(PORTR, 0)
    #define LED1_GPIO                       IOPORT_CREATE_PIN(PORTR, 1)
    #define LED0                            LED0_GPIO
    #define LED1                            LED1_GPIO
    好吧,到这里应该是看懂了,IOPORT_CREATE_PIN(PORTR, 0)  这句函数是定义了 端口PR0,然后这句gpio_set_pin_low(LED0);
    是将PR0端口置0
    我以前学AVR单片机得知  AVR单片机的I/O口 是要定义它为输入模式还是输出模式的
    好吧,我打开了
    然后吃了一惊,ASF 果然是神器    神马预定义的函数都写好了 ,都可以直接拿来调用,节省开发时间。
    ····················································································································································································································································································································································································································································································  最近实在是太忙了,各种考试,琐事缠身,但是 但是  还是阻挡不了我对 ASF 的狂热,晚上抽空就研究了下 ATXMEGA256的串口通讯的代码测试:
        首先是  1 初始化    2设置波特率   3设置数据位数、停止位、校验位    4打开    5发送或者接收数据
        代码:
    #include <asf.h>
    //&USARTD0发送     &USARTE0接收
    #define USART_SERIAL_BAUDRATE               9600
    #define USART_SERIAL_CHAR_LENGTH         USART_CHSIZE_8BIT_gc
    #define USART_SERIAL_PARITY                     USART_PMODE_DISABLED_gc
    #define USART_SERIAL_STOP_BIT                 false
    int main (void)
    board_init();
    //Create USART options struct
    static usart_rs232_options_t USART_SERIAL_OPTIONS = {
      .baudrate = USART_SERIAL_BAUDRATE,
      .charlength = USART_SERIAL_CHAR_LENGTH,
      .paritytype = USART_SERIAL_PARITY,
      .stopbits = USART_SERIAL_STOP_BIT
    sysclk_enable_module(SYSCLK_PORT_D, PR_USART0_bm);//Enable the clock for the USART module
    usart_init_rs232(&USARTD0, &USART_SERIAL_OPTIONS);//Initialize in RS232 mode:
    sysclk_enable_module(SYSCLK_PORT_E, PR_USART0_bm);//Enable the clock for the USART module
    usart_init_rs232(&USARTE0, &USART_SERIAL_OPTIONS);//Initialize in RS232 mode:
    uint8_t received_byte;//A variable for the received byte must be added:
    while(1)
           usart_putchar(&USARTD0, 'a');//Send an 'a' character via USART
            received_byte = usart_getchar(&USARTE0);//Wait for reception of a character:
            usart_putchar(&USARTE0, received_byte);//Echo the character back:
            if (    received_byte=='a'   )
                 delay_ms(2000); //调用ASF框架函数延时500Ms
                 received_byte=0;     //经过测试  必须加上这一条置0语句,否则会见到LED0一直亮着
                 delay_ms(2000);      //经过测试  也要加上这个延迟,否则也看不到效果     预计是因为CPU的指令运算速度太快了,上一句 received_byte=0  没来得及反应 就又有 received_byte=='a'   然后也是LED会一直亮着
    传上视频哈
       我用的是串口USARTD0  发生一个字符a,用USARTE0去接收字符,如果接收到字符,就让LED0灯闪亮。
    之前打算用  USARTD0 发生 USARTD1  去接收的,可是在
    看到 USARTD0  用的的RXD0 、TXD0 为PD2、PD3  , USARTD1 用的的RXD1 、TXD1 为PD6、PD7    而 A3BU Xplained板子的J1 J2 J3 J4 木有引出 PD6、PD7     在板子的PCB图上见到这个 PD6、PD7 用于USB转串口去了 。
    就随手改了板子引出的资源 USARTE0     对应的是 PE2    PE3
    有一点很奇怪  当我打开 ASF 资源中的  usart.c 文件    找到
    #ifdef USARTC0
    if ((uint16_t)usart == (uint16_t)&USARTC0) {
      sck_pin = IOPORT_CREATE_PIN(PORTC, 1);
    #endif
    #ifdef USARTC1
    if ((uint16_t)usart == (uint16_t)&USARTC1) {
      sck_pin = IOPORT_CREATE_PIN(PORTC, 5);
    #endif
    #ifdef USARTD0
    if ((uint16_t)usart == (uint16_t)&USARTD0) {
      sck_pin = IOPORT_CREATE_PIN(PORTD, 1);
    #endif
    #ifdef USARTD1
    if ((uint16_t)usart == (uint16_t)&USARTD1) {
      sck_pin = IOPORT_CREATE_PIN(PORTD, 5);
    开始以为这些语句的意思是   把PC1作为USARTC0 的输入端    PC5作为 USARTC1的输入端  很显然不对的。与上面芯片的引脚图注解不对应
    看来还得好好研究下usart.c   里面的语句。
  • 签到天数: 361 天
    发表于 2013-4-11 08:26:20 | 显示全部楼层
    {:soso_e179:}{:soso_e179:}{:soso_e179:}{:soso_e179:}
    发表于 2014-1-22 20:32:29 | 显示全部楼层
    板子怎么来的呀?
    GMT+8, 2024-12-21 01:10 , Processed in 0.150106 second(s), 20 queries , MemCache On.
